Check engine light!
Old Dec 23, 2001 | 03:24 PM
Crossett's Avatar
Default Check engine light!
I gutted my cat today, everything went fine no problems. After a couple hours of driving I got a check engine code (67).
Hybrid honda says that this code means
"malfunctioning or defective oxygen sensor heater"
What is wrong and how do I fix it?
Old Dec 23, 2001 | 03:27 PM
ITR41's Avatar
New User
Default Re: Check engine light! (Crossett)
talk to NekkedR he got a test pipe and still doesn't get a check engine with what he did....
Old Dec 23, 2001 | 05:04 PM
Padawan's Avatar
Darth ModerVader
Your secondary O2 sensor is telling the ECU that the cat isn't doing its job, (because none of the material is there anymore) thus throwing a code. There are a few solutions that people have come up with, such as wrapping the 02 sensor in foil before installing it in the cat or zip-tying the sensor next to the cat. You might want to check out the groupbuy center where there's a special on 02 simulators for testpipe (or gutted cat) users. Either way, the overall consensus is that a CEL caused by the secondary 02 sensor will not cause a loss in performance, so if you can deal with the CEL glaring at you then it shouldn't be a problem. HTH
Old Dec 24, 2001 | 09:35 AM
Crossett's Avatar
Default Re: Check engine light! (SpecR0123)
thanks
Old Dec 24, 2001 | 11:25 AM
Teepo's Avatar
Or put some black tape in front of the light
Old Dec 24, 2001 | 07:08 PM
flex97itr's Avatar
Default Re: Check engine light! (ITR1150)
hey itr1150 where in the bronx are you from?
bma1818
11
Apr 20, 2006 02:11 PM
bma1818
Apr 19, 2006 09:55 PM
halfNhalf-83
Nov 20, 2003 11:12 PM
onyx00
Apr 16, 2002 01:00 PM
AllMotorBLKITR731
Oct 17, 2001 12:39 PM
