engine light on
Old Mar 26, 2005 | 06:17 PM
brad98_teg's Avatar
Default engine light on
I just installed my GReddy sp2 and in the process decided to hollow out my CAT.
Its been about 2 days and the engine light just came on.Is the from the O2 sensor goin off? since all the dick it gettin through my cat.
thanks
Old Mar 26, 2005 | 06:23 PM
stivic's Avatar
Default Re: engine light on (brad98_teg)
yeah most likely is the O2 sensor but u can flash the code to find out for sure
Old Mar 26, 2005 | 07:30 PM
brad98_teg's Avatar
how do you flash the code?
Old Mar 27, 2005 | 07:11 AM
brad98_teg's Avatar
bump
Old Mar 27, 2005 | 07:36 AM
Stripped Honda's Avatar
99-0104
Default Re: (brad98_teg)
sounds like you have a 96 and up integra with a o2 sensor behind the cat and if you hollowed out your cat it would take a day or two for the CEL to come on ... either get a new cat or a o2 simulator and it will solve your problem
Old Mar 27, 2005 | 07:58 AM
neo1z's Avatar
Default Re: (Stripped Honda)
Do you know how to jump the little clip to see your code?
Well, regardless its probably that O2 code anyway.
You can get a new ecu to eliminate it, you can get a simulator...any number of options.
Is your car in limp mode?
Old Mar 27, 2005 | 03:03 PM
brad98_teg's Avatar
what is limp mode?it still pulls hard if limp mode slows it down.
Old Mar 28, 2005 | 04:32 AM
brad98_teg's Avatar
bump
Old Mar 28, 2005 | 06:17 AM
Backk InTheDA's Avatar
I hate everything
Sounds like an O2 to me as well. Just get a simulator, or perform a check engine light search if your not satisfied with that simulator, and then refer to the ECU code thread at the top of this page.
iTR
streetracerjoey210
Jun 24, 2007 04:48 PM
mr0lg
Dec 9, 2005 06:19 PM
stefanne3
Oct 19, 2004 02:09 PM
tegrunner
Sep 11, 2003 07:54 PM
AllMotorBLKITR731
Oct 17, 2001 12:39 PM
