If i take out the spring off the wastegate will it be 0lbs of boost???
Re: If i take out the spring off the wastegate will it be 0lbs of boost??? (juniestyle)
well your car would be really slow .....but seriosuly i wouldn't go railing on it with the spring out....if you need it that way just to get around then it should be fine.
Re: If i take out the spring off the wastegate will it be 0lbs of boost??? (mr_hahn73)
are you doing this for emmissions? or somthing cause i have heard of people doing this when using FMU's
Re: If i take out the spring off the wastegate will it be 0lbs of boost??? (JDM00SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_hahn73 »</TD></TR><TR><TD CLASS="quote">Why did you want to do this in the first place?</TD></TR></TABLE>
one reason would be if you have to go to get the motor tuned and its a longer drive to the tuners shop, pull the spring and it wouldnt boost
yes...im doing this because im going to drive the car for awhile b4 i can get my car tuned
ATgrills.com
04-21-2005 03:34 PM
Cyber ITR
01-19-2004 03:38 AM
