are my vacuum lines right?
Old Jun 4, 2002 | 05:27 PM
ceemarun's Avatar
Default are my vacuum lines right?
im preparing to do an install, and im trying to figure out where which vacuum lines go. my setup is using a fpr, dsms, hondata, fuel pump, on a 99 gsr w/ an fmax kit.
line from bov to some sort of tee leading one of the fpr and another to my boost gauge
on my tial, on the top one, i'll hook that up to the turbo, the other to where? i know i have all this 100% wrong. correct me please.
Old Jun 4, 2002 | 06:28 PM
inspyral's Avatar
Default Re: are my vacuum lines right? (ceemarun)
The side fitting on your TiAL goes to the compressor side of the turbo. The top fitting on the TiAL can be left open to the atmosphere if you're not running a boost controller. For your BOV, gauge, etc, try not to have too many things tee'd off the same manifold pressure source. Ideally they would all have their own line, but this isn't always possible.
Old Jun 4, 2002 | 06:33 PM
ceemarun's Avatar
Default Re: are my vacuum lines right? (inspyral)
so side of the wg goes to the compressor. let me get this straight also:
the vacuum line to the fpr, i cut that. i tap a bov hose into there, and another vacuum to the boost gauge. am i right?
b18psi
Aug 20, 2018 06:05 AM
dcintegra88
Jan 18, 2010 01:42 PM
90AcuraIntegra04
Jan 28, 2006 07:02 PM
seeeya04
Dec 1, 2005 06:40 AM
SlowB16
Jan 7, 2002 04:04 PM
