BOV rattles
Old Feb 14, 2015 | 09:46 AM
diatibe24's Avatar
Default BOV rattles
Just finished getting my car back together and am now chasing down the demons. One of them is the BOV rattles at idle. Any clue what it could be?
Details,
-Tial 50mm BOV
-Less than 2k miles on it
-Vacuum source is from the port on the intake manifold from where the PCV valve hose used to connect on the front
The BOV valve does stay completely open at idle. If you blip the throttle it will move the valve.
I used to use the nipple on the back of the IM for where the cruise control was hooked up to and it was fine. I just used a bigger hose and am running it off the aforementioned spot now (where the PCV used to be). Now i get a obnoxious rattle.
Old Feb 14, 2015 | 09:50 AM
diatibe24's Avatar
Default Re: BOV rattles
Current engine pic if it helps?
Old Feb 14, 2015 | 09:14 PM
viper_boy403's Avatar
Change the spring. I've always gone softer with Tial's since they seal up quite well under boost. Better than too stiff
Old Feb 15, 2015 | 04:14 AM
diatibe24's Avatar
I have the softest spring in it now (Black One) which is 6psi. I am going to change it out to the 11psi one which I think should work. Its just 2 steps above the one I currently have.
Builda'Teg_92
May 14, 2013 11:48 AM
Jupe
Jul 8, 2007 02:42 PM
wambus
Sep 18, 2006 03:31 AM
a1320addict
Apr 29, 2005 06:01 PM
_Endless_
Jan 22, 2004 09:36 PM
