bov problems. need help
Old Apr 15, 2005 | 02:31 AM
eatbieodie2's Avatar
Default bov problems. need help
my blow off valve is not going off. i have boost but the bov is not makin any noise. can any one help? thanks
Old Apr 15, 2005 | 03:39 AM
tegon-gsr's Avatar
Default Re: bov problems. need help (eatbieodie2)
check to see if you have all hose's on correctly it would help if you let us know what kind also
Old Apr 15, 2005 | 05:41 PM
Default Re: bov problems. need help (tegon-gsr)
its an apexi twin chamber. is it bad to ues one vacume soruce for fmu,wastegate,and bov
Old Apr 15, 2005 | 05:43 PM
where should i get the vacume soruces from. turbo is on my 96 teg Ls
Old Apr 15, 2005 | 06:44 PM
Evanmb44's Avatar
t into the line from the intake manifold to the fpr. or get a vacuum manifold and run that off the brake booster
Old Apr 15, 2005 | 09:07 PM
Default Re: bov problems. need help (Turboaddict)
i did t the fpr for my fmu,wastegate,and bov. i was wondering is it bad to run that much on one vacume soruces.
Old Apr 15, 2005 | 09:33 PM
PrettyLude's Avatar
you would need to tee it into the brake booster with a vacuum manifold
i wouldn't do it your way
Old Apr 15, 2005 | 10:23 PM
BoostfedEK4's Avatar
you shouldn't have everything T'd off at the fpr line. you should use your brake booster line at least.
Old Apr 16, 2005 | 12:28 PM
Default Re: (PrettyLude)
why a vacume manifold? is it not the same. cause it is still takeing from one vacume sorces
Old Apr 16, 2005 | 04:40 PM
PrettyLude's Avatar
Default Re: (eatbieodie2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eatbieodie2 &raquo;</TD></TR><TR><TD CLASS="quote">why a vacume manifold? is it not the same. cause it is still takeing from one vacume sorces </TD></TR></TABLE>
its the same, but you have a more stronger source
Old Apr 20, 2005 | 09:23 PM
i T the break booster for the bov and still nothing
99civichx
Jan 10, 2011 02:52 PM
superslow-oto
Nov 6, 2007 02:42 PM
dumas07
Apr 9, 2007 02:04 AM
HondaCutter
Sep 26, 2002 04:20 PM
Integra_Boi
Aug 13, 2002 02:10 AM
