How much vacuum should the bov need?
Old Aug 10, 2002 | 07:02 AM
Integra_Boi's Avatar
New User
Default How much vacuum should the bov need?
should it have its own vacuum source? i heard of people tapping into the pcv valve..
Old Aug 10, 2002 | 07:23 AM
93LSivic's Avatar
Default Re: How much vacuum should the bov need? (Integra_Boi)
Why tap the PCV valve? You really want oil being pulled into it?
Use its own vac source, or share with others vac needs. FPR is good. I use the brake booster vac solely for my wastegate.
Old Aug 10, 2002 | 07:27 AM
New User
Default Re: How much vacuum should the bov need? (93LSivic)
i just read somewhere that he tapped the pcv and it stopped fluttering.. but i think it flutters because of the vacuum source...
Old Aug 10, 2002 | 10:53 AM
intekragsr's Avatar
mine fluttered until I hooked it up to its own source.
Old Aug 10, 2002 | 12:24 PM
shadowdawn's Avatar
Default Re: How much vacuum should the bov need? (intekragsr)
mine fluttered a little when I had 4 things on the FPR line, then I move the WG and BOV to the brake booster and everything seems much better
Old Aug 10, 2002 | 09:31 PM
New User
Default Re: How much vacuum should the bov need? (shadowdawn)
which one is the brake booster vacuum? got a pic?
Old Aug 10, 2002 | 10:07 PM
rjardy's Avatar
its the line coming off of your brake booster, that big round blackthing that your mastercylinder is connected to.
Rob
Old Aug 11, 2002 | 08:56 AM
B18EG6's Avatar
Default Re: How much vacuum should the bov need? (rjardy)
the brake booster is the large vacuum line coming off of the top right of the intake manifold that goes towards he firewall.
Old Aug 11, 2002 | 09:52 AM
93LSivic's Avatar
Default Re: How much vacuum should the bov need? (B18EG6)
be sure to "t" it between the checkvalve and the manifold. Bad things can happen if you dont.
Old Aug 12, 2002 | 02:38 AM
B18EG6's Avatar
check this out...i saw this a few days ago thought it would help..
https://honda-tech.com/zerothread?id=247190
Old Aug 12, 2002 | 05:10 AM
Dee's Avatar
Dee
The little blue block sitting on top of my fuel rail and beside the FPR is my "VACUUM MANIFOLD". It's a 6 port tee for air tools. FPR, boost gauge sensor, and BOV get their vacuum signal from this spot. The AVC-R pressure sensor gets it's vaccum signal from the backside port on the Skunk2 mani. The W/G gets it's vacuum/boost signal from the IC piping. This tee cost me $3.00 !
Old Aug 12, 2002 | 10:28 AM
wickedxboi's Avatar
Default Re: How much vacuum should the bov need? (Dee)
where can you get something like that?
Old Aug 12, 2002 | 10:50 AM
MyWhiteCivic's Avatar
Default Re: How much vacuum should the bov need? (wickedxboi)
Yeah, I need one too.
Old Aug 13, 2002 | 02:10 AM
Dee's Avatar
Dee
Default Re: How much vacuum should the bov need? (MyWhiteCivic)
Try a store that sells air tools. I'm in Japan so I just didy-bopped down to the neighborhood hardware store!
playa6188
Feb 13, 2006 07:13 PM
igo4bmx
Nov 27, 2004 06:50 PM
spark plugs.
Apr 28, 2004 04:58 AM
_Endless_
Oct 4, 2002 12:28 AM
