Boosting Problem help!!!!!!!!
Old Nov 21, 2003 | 06:58 PM
BoOsTiN Dc2's Avatar
Default Boosting Problem help!!!!!!!!
Ok here is the problem, i'm running a ls vtec wit gsr head and gsr tranny. my problem is when i'm racing in 2nd 3rd and 4th gear when it hits about 5-6k rpm on almost full throttle i hear the turbo spooling hella hard and it doesnt pull until i pump the gas a lil or ease up on the gas until like 1/3 of throttle... anyone think they might know what the problem is? i think i might be leaning out or something. the wastegate is 10 psi spring but it only reach up to about no more then 8 lbs. any help is appreciated. thanks in advance. specs are listed.
turbonetics t3/t4 .57 trim ar 63
hks 40mm wastegate 10 psi spring but boost only hit about max 8
greddy type r bov
spearco IC
drag cast iron manifold
vortech fmu not sure what the spec is
missing link
stock integra injectors
2.5 downpipe/exhaust
act 4 puck xtreme
jg tb
b&M fpr
Old Nov 21, 2003 | 07:05 PM
AlphaKennyWun's Avatar
Default Re: Boosting Problem help!!!!!!!! (tRaCeBuStAbUsTeR)
fuel pump?
Old Nov 21, 2003 | 07:12 PM
Default Re: Boosting Problem help!!!!!!!! (S03Burner)
yeah i have a bbk 255 lph fuel pump.
stock p72 ecu obd1
Old Nov 21, 2003 | 07:29 PM
I guess its not the fuel pump then. I remember feeling what you described when I was running boost off the wastegate. Since I bought a mbc its got a lot better. Maybe its the spring on the WG opening prematurely and that is the loss of power you describe? Then when you lay off the throttle it closes a bit again? I dont think you could actually "feel" the leaning out so easily as you described.
I would buy a mbc. You could get to 10 psi and the wastegate would open a little later. I have the turbonetics and it holds 14 psi w/o problems. $40 bucks too.
Old Nov 21, 2003 | 07:48 PM
well i ordered the turbonetics mbc and its in my garage now not installed yet... i dont wanna install it yet because i dont wanna boost more then what it is right now. i'm pretty sure i'm gonna blow if i boost anymore then what it is right now. let me know what you guys think, thanks
Old Nov 21, 2003 | 08:10 PM
x2gold's Avatar
all that and you have stock injectors?
Old Nov 21, 2003 | 08:12 PM
Default Re: Boosting Problem help!!!!!!!! (x2gold)
yeah for now until i put my internals in and 720cc and hondata.... i have everything already just gotta piece it together and get it tuned
forcefedh22
Feb 12, 2005 09:08 PM
eGeeHaTcH
Jan 16, 2005 02:43 PM
J.P. 4rm The dPk*
Sep 26, 2004 12:07 AM
rusteds2k
Dec 13, 2003 05:24 PM
turbogsr13z
Mar 16, 2002 12:16 PM
