boosting my civic
its a d16z6 motor..i need help on where the oil feed line will go on my block and where i can find Tees for it....i also need help on wat engine management anyone uses and tuning and tuning chip..please i need help asap
Also, check out Phearable.net, one of the many good companies, for all your ECU needs:
https://honda-tech.com/forums/forced-induction-49/chipped-p28s-ecus-phearable-net-chip-kits-crome-hondata-neptune-ectune-2720357/
sorry bout the late reply...but yes i checked and i didnt get it:
things i have:
hf manifold
td05h turbo(not sure if 15g or 16g)help?
bov
wastegate came on turbo
oil feed line
oil drain line
450cc injectors
resistor box
side mount intercooler
things im considering:
fmic
things i need:
a/f gauge
boost gauge
boost control ****(right?)
charged piping
tuning!!(biggest problem)
custom downpipe
things ill need that i dont know:
i am just turboing for a year until i can build a bottom end for it and turn up the boost
what else do i need to just get boost right now????
things i have:
hf manifold
bov
oil feed line
oil drain line
450cc injectors
resistor box
fmic
things i need:
a/f gauge
boost gauge
charged piping
custom downpipe
You can go with Phearable, but that's just a base map. Not an actual tune. If you can get the Hondata S300, but if you're on a budget, get a hold ectune, or chrome for your engine management. I would consider a fuel pump also. Walbro 255 will do.
i just did a sandwhich plate i like that better then the tee and tuning just go all out you can not cut corners with your engine management i run an aem ems you can find them for almost the same price of a new s300
things i have:
hf manifold
bov
oil feed line
oil drain line
450cc injectors
resistor box
fmic
things i need:
a/f gauge
boost gauge
charged piping
custom downpipe
things i have:
hf manifold
bov
oil feed line
oil drain line
450cc injectors
resistor box
fmic
things i need:
a/f gauge
boost gauge
charged piping
custom downpipe
CivicNewbie
Jan 24, 2002 07:01 PM
