Need Earl's oil feed/return line part #'s
I am trying to peice together my oil return and feed line but want to know exactly what I need so I don't waste money on the wrong parts. Anyway, I plan on using -8 oil return (approx. 15 in.) and -4 oil lines( approx. 48 in.) other than that I am not 100% sure. So if anyone can give me that part #'s or at best a good discription of what I need that would help me out a great deal. Thanks
Re: Need Earl's oil feed/return line part #'s (snt78)
this was from someone elses post on this....
OK, I just spent a half hour putting together a shopping list for you. Keep in mind this is exactly how I did my feed/return system. I decided not to use the factory oil sensor because i went with a mechanical oil pressure gauge that runs off the feed "T" coming off the block. Also I used a union in the pan---drilled bigass hole and sealed with silicon, in this case Im giving you stratoseal p/n so you can do it right (which I didnt do--in light of getting turbo install done)
All part numbers are from amstreetrod.com ---best prices and parts are always in stock.
Feed:
1/8 nipple for block -- 991101
1/8 "T" -- 991701
1/8 to -4AN -- 981604
(2 needed) -4AN straight swivelseal hose ends -- 300104
(4 ft needed) -4AN ss hose -- 400040
For adapter to turbo you will need one of these depending on the size of the hole on the turbo itself.....
1/8 npt hole 982204 (Smaller T3's use this one I believe)
1/4 npt hole 982244 (This was the one I used for my t3t4)
Return:
Aluminum return flange found at turbocharged.com p/n is 20259.
-10AN flange side male to hose -- 824510
(2 ft needed) -10AN hose -- 400100
-10AN 45 to pan fitting -- 804610
-10AN union for tapping pan -- 981510
-10AN bluhead nut for union in pan -- 992410
Stratoseal for union (package includes 2) -- 178014
Feed:
1/8 "T" -- 991701
Return:
pcguy760
07-15-2008 07:12 PM
