Boostie 2012
Edit- nvm saw that you installed the cams b4 getting the .82
Soooo after trying both S2 cams and the GSC's, which would you prefer for your set-up after your experience with the S2's and now the GSC's. If you had neither, but both were free which would you choose?
The S2 cams and .63ar exhaust worked together better. Car drove better and made more power. I'm sure others may have different opinions.
S2 Tuner 1's ARE NOT the same as ITR/CTR cams keep this in mind. Many folks make fantastic power on GSR cams no need to over complicate things. Pair cams and turbo manifolds.
sorry for all these small questions, bored at work so i figured i'd ask you some random questions, thanks for the info so far.
How do you find humor in that? Swapping EXH housings is one o the cheapest tests you can do. Unless you need to be hand fed information I think it's a valid suggestion.…...................................... .................
mellow out my man(might help with your Harlem shakes at the tree lol), i was just trying to bullshit with you while i was at work about your set-up.
gringotegra
Oct 20, 2020 04:04 PM
