boosted b16 bogging down
Old Mar 12, 2014 | 05:51 AM
Maxman's Avatar
Default boosted b16 bogging down
I've got a 94 civic with a boosted b16. I was having an idle surge issue and I've bleed the coolant system and it didn't really help. So I adjusted the idle screw and that fixed that but a couple days after that it started to bog down when the motor was cold and then stops when the motor heats up now my air fuel gauge goes from lean to rich randomly when it bogs it says its rich. I get a check engine light every now and then but I can't find the plug to jump so I can find out what the codes are.
Old Mar 12, 2014 | 06:25 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: boosted b16 bogging down
What ECU are you using? Is it Tuned(not base mapped)?
Look in the FAQs to figure out how to pull the CEL code.
Old Mar 12, 2014 | 06:31 AM
Maxman's Avatar
I just bought the car so I'm not sure what ecu it has. From what I was told it's been tuned.
Old Mar 13, 2014 | 05:10 AM
ls joker's Avatar
Loved
needs fuel taken out
Old Mar 17, 2014 | 01:26 PM
Maxman's Avatar
When it bogs it shows lean
Old Mar 18, 2014 | 07:40 AM
SH4DY's Avatar
Which is it?
Do you have a wideband A/F gauge or a cheap narrowband?
When does it bog down? Tip-in, constant throttle, under boost, etc...?
Old Mar 18, 2014 | 08:18 AM
Maxman's Avatar
Normal cruising no boost it goes lean. When it does that I can give it gas and it will richen up. I have a wideband.
Old Mar 24, 2014 | 04:17 AM
Maxman's Avatar
Any suggestions?
z06eateR
10
Jun 22, 2012 05:45 PM
97grnrs
Nov 6, 2006 06:42 PM
ID_ten_T
Apr 20, 2004 07:58 AM
rtiadnoh
Feb 27, 2004 05:19 PM
02WRX
81
Jan 24, 2004 05:31 PM
