ls vtec running lean?? why
Old Nov 5, 2006 | 01:38 PM
97grnrs's Avatar
Default ls vtec running lean?? why
its in a 89 hatch . obd0 using a jdm b16 ecu. we have tried everything. ignition timing is set and we have tried different fuel pressures too. right now its set at 40 psi at idle. its also being fed by a 255 lph fuel pump. we replaced fuel filter and plugs and o2 sensor. but on the air fuel gauge it no longer even goes back and fourth at idle it just goes from somewhat stoich to lean and stays lean. and stays lean when driving too, plugs look whitish in color.it seems to have a slight bog too when just quickly tapping the throttle .then it revs up. any ideas?
Old Nov 6, 2006 | 05:57 AM
b16civster's Avatar
Default Re: ls vtec running lean?? why (97grnrs)
THE B16 ECU IS MEANT TO RUN A 1.6L ENGINE NOT A MODIFYED 1.8L DID YOU CHIP THE ECU???
Old Nov 6, 2006 | 06:42 PM
97grnrs's Avatar
Default Re: ls vtec running lean?? why (b16civster)
its my friends car . and no he didnt. but he had the same problem when he was running a normal b16 too.
Kenzo206
Apr 24, 2009 02:59 PM
Hatch8
Oct 25, 2004 06:30 PM
VtecDA9
Jun 28, 2003 11:58 AM
ls_vtec_b18a1
Oct 30, 2002 08:53 PM
InfamousRS
May 29, 2002 08:39 AM
