boost problem and vacuum source
Old Jun 4, 2006 | 10:36 AM
Makdaddynuge's Avatar
Default boost problem and vacuum source
Ok first off, let me say i searched a lot and i am getting mixed answers everywhere.
I am having boost problems, i am creeping boost. Right now i have a T off the brake booster then i have a T off that line to go to the wastegate and BOV. Is this a problem for me? I've been thinking about tapping my turbo and running my wastegate vac soure from there, but some people don't recomend that. So basically i am wanting to know where is the proper place for my vac source for my wastegate so i don't creep. Tap the turbo or run GE vacuum box? Any help is appreciated.
Old Jun 4, 2006 | 11:34 AM
RedR's Avatar
Default Re: boost problem and vacuum source (Makdaddynuge)
what manifold is it? wg size? how much psi?
Old Jun 4, 2006 | 12:49 PM
full-race, 44mm, 3 psi spring...7psi spring was in in before and it creeped up to 10+ but boost cut hit, then we put 3 psi spring in and it creeps to 6.
Old Jun 4, 2006 | 02:43 PM
RedR's Avatar
With that setup its normal to creep at low boost (same as mine) , i have the 7 psi spring at it creeps to 9.5, u could try the GE vaccum mani but it will prolly creep too.
Check your vaccum line for leaks though.
Old Jun 4, 2006 | 03:46 PM
alright thanks
chriskey0829
Feb 1, 2006 07:10 PM
B18 rider
Aug 23, 2005 01:08 PM
evilk
Aug 21, 2005 06:23 PM
B16CRXT
Apr 24, 2005 07:50 PM
Turbocivic94
Aug 7, 2003 05:39 AM
