boost newb
Old Mar 16, 2009 | 02:09 PM
eg-greeny's Avatar
Default boost newb
hi guys im new here and im currently wire tucking and smoothing an eg hatch. the car is bare at the moment and is nearing time for the respray. im hoping to get something special done with the b16 im currently running, im making the rest of the car special so wanted to go possibly down the boost route. after reading a post by a fellow uk member about boost i wanted to ask about the treadstone performance b-series kit. i wanted to know what experiences people had with these kits good or bad and if the kit would be suitable for a goal bhp of 300 at the wheels?
id be planning on using arp headbolts and rodbolts, uprated bearings and some decent rods and low comp pistons. also what pistons, rods, bolts and bearings would you bguys advise??
much thanks
Old Mar 16, 2009 | 06:15 PM
SilverEk3dr's Avatar
Default Re: boost newb
Your choice of piston. Not sure there is a big diff between all of them. Crower, pauter, or manley for the rods. Oem for the bearings. Arps for the head, all the rods will come with their own bolts. That should be good for way more power than most off the shelf kits will make.
Old Mar 17, 2009 | 08:10 AM
Ls_dx's Avatar
Just go with some SRP pistons, eagle rods, clevite/king/acl bearings, honda head gasket, type R cams, some bigger injectors and a little bit of tuning should be running nicely in no time.
Old Mar 17, 2009 | 10:44 AM
eg-greeny's Avatar
im alreaddy running ek9 cams, sk2 valve springs, valves and retainers.
ive also got a hondata s200 for mapping
is the turbo kit im looking at going to do the job bhp wise? and is it a good choice?
also should i considder getting the block sleeved as ive heard bad things about just fitting block guards?
Pasghetti
Jul 17, 2010 05:34 PM
n17r0us
Oct 13, 2009 04:51 PM
AJxr
Mar 4, 2006 08:42 PM
n.e.coupe
Sep 15, 2005 08:10 AM
boostedsol
Mar 23, 2003 07:20 PM
