should i get arp rod bolts
k i'm building a block for boost i'm using low compression pistons and putting new bearings in i am using the stock rods do i need arp rod bolts or will the stock rod bolts work fine ? any help is appreciated redline will be the stock 7000
Re: should i get arp rod bolts
i'm reusing the stock rods and got a deal on pistons this is a budget build will i benefit from arp rod bolts or will the stock ones be fine only going for 250 horse
when you put arp rod bolts in you will need to rehone the rods. by the time you pay to press the pins in and buy the rod bolts and rehone the rods......you could have just got eagle rods. i found this out from a friends build...lol
I know this is accepted as correct information, but I and a bunch of others have swapped in ARP rod bolts without re-sizing the big end, and it works great.
