Boost and Boom!!!!! Help
Old Oct 6, 2005 | 08:05 AM
1badEk9's Avatar
Default Boost and Boom!!!!! Help
I gave you guys the good new that my turbo project finally got up and running. Well bad news. I either blow a head Gasket or have two bad pistons. I was driving my car after all the ignition problems were solved with a change for the Accel super coil to the MSD ss blaster. I drove the car around for about 60-75 miles and on the way home I ran my cousins Srt-4 with 280hp and 290ftlbs and hung right with on the first run. It with down hill from there.
First off oil started coming out of my valve cover weremy breather filter is. Then we I pulled of I saw a lot of White blueish smoke. So we drove the car home 2 miles. Have a compression check and here is the results
Cranking 1: 140psi 2: 190psi 3: 190psi 4: 113psi Running 1: 85psi 2: 90psi 3: 95psi 4: 80psi.
Some of my friends say they think it just a head gasket. I haven't drop the oil yet to see if there is any metal in the pan. I thing the white smoke is from the turbo my downpipe has little cracks in it and I see oil bubbling out it smokes after the car is warmed up about 3-5 min but not when i first start it. Which leads my to think that the smoke is the byproduct of oil in the exhaust.
There is some knocking, or ticking but if I rev the engine it get quieter not louder like connecting rod noise and it totally goes away when the oil temp gets up. Crazy right, I know.
Does someone have a clue
Old Oct 6, 2005 | 09:02 AM
bubbahatch92's Avatar
Default Re: Boost and Boom!!!!! Help (1badEk9)
Your rinlands are gone buddy and probably some bearings also if it's nocking. Tear it down and rebuild or find yourself a short block.
Old Oct 6, 2005 | 09:40 AM
stackz's Avatar
at the jetties fishin'
Community Builder
rod knock can also go away with increased rpms if it isnt too severe into the process of egging out the surfaces...
Old Oct 6, 2005 | 10:16 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1badEk9 &raquo;</TD></TR><TR><TD CLASS="quote">we drove the car home 2 miles. Have a compression check and here is the results
whoa - never heard of doing a compression test while the car's RUNNING, how does that work?
as was said above, your ringlands are probably gone...
Old Oct 6, 2005 | 12:07 PM
flood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1badEk9 &raquo;</TD></TR><TR><TD CLASS="quote">I gave you guys the good new that my turbo project finally got up and running.
I ran my cousins Srt-4 with 280hp and 290ftlbs and hung right with on the first run. It with down hill from there.</TD></TR></TABLE>
With every story there is a beginning and an end. A little soon to be racing? did you wideband it or anything?
Old Oct 6, 2005 | 12:16 PM
yee SERIOUS's Avatar
sounds bad. maybe it's your ringlands like everyone stated.
Old Oct 6, 2005 | 12:44 PM
Sketch_hs's Avatar
i vote all 4 ringlands
time for forged!
JDM_EK4_Coupe
Jun 26, 2007 10:28 AM
1badEk9
10
Oct 6, 2005 08:55 AM
VanHonda
Jun 11, 2003 07:24 PM
youngkow
Jun 4, 2003 08:14 AM
MisterHYBRID
Jan 27, 2003 12:17 PM
