blue smoke again...
Old Apr 29, 2002 | 08:44 PM
  #26
Cyber ITR's Avatar
Default Re: blue smoke again... (Tomakit)
is it possible to have good compression with fucked up oil rings ?!?!?
Old Apr 30, 2002 | 01:43 AM
  #27
MiraiZ's Avatar
Default Re: blue smoke again... (94hondahybrid)
Yeah..i 'm going to troublshoot from the easiest to the hardest. I have a strong suspision that its my crankcase breather setup....I am using a very small diameter vacuum line to connect the breather on the valve cover to the intake pipe....when I found oil in the intake pipe...I notice that there was more oil toward the filter than the turbo....wishful thinking? maybe....but this is where I'm starting
Old May 2, 2002 | 09:38 PM
  #28
MiraiZ's Avatar
Default Re: blue smoke again... (MiraiZ)
...Update:
okay...I did all of the easy stuff today....I pulled the PCV valve and cleaned it with brake cleaner...I blew into it and air seemed to go through it freely (one way)...changed the oil from Mobile 1 5w-40 (synth) to Nissan GT-R 10w-50 (synth)....they didn't work...the smoke seemed to have become lighter in color (maybe my imagination) none-the-less the smoke is still there. The smoke really smells badly (like sulfer)...So it may be valve stem seals or oil rings. I can't tell...I also noticed droplets of water in the exhaust...
Digest:
Blue smoke
tried changing to a higher viscosity oil (stayed synth)
cleaned PCV valve...no clogs
blue smoke seems to have gotton lighter in color but same amount
smell like sulfer or real stale gas
Questions about blowby:
1.Does it cause backfire?
2. The valve cover nippe that connects to the intake pipe or crankcase breather: Is it suppose to be sucking or blowing air?
3. what can cause excessive crankcase pressure?
4. Can a PCV valve that seems to work, still be malfunctioning and causing the symptoms above?
[Modified by MiraiZ, 3:45 PM 5/3/2002]
MiraiZ
Apr 2, 2013 07:51 AM
T25So
Sep 8, 2004 11:39 AM
playAho
Apr 16, 2004 04:57 PM
vxnine
18
Oct 11, 2003 07:24 PM
Cyber ITR
Jan 7, 2002 05:10 PM
