tial wg 38mm spring..help..
Old May 4, 2004 | 11:45 AM
jure's Avatar
Default tial wg 38mm spring..help..
How much boost can I run with that spring?A also have profec b boost controler..
Thanx..
Old May 4, 2004 | 11:54 AM
jure's Avatar
Default Re: tial wg 38mm spring..help.. (jure)
anyone?I'm totaly confused, I would like to run about 15psi of boost..anyone know where i can get another spring if this is wrong..
Old May 4, 2004 | 12:03 PM
SpoolnG2's Avatar
TIAL Big Blue Spring 1 Bar, 14.5 PSI
TIAL Small Blue Spring .8 Bar, 11.60 PSI
TIAL Small Green Spring .65 Bar, 9.43 PSI
TIAL Small Red Spring .45 Bar, 6.53 PSI
TIAL Small Yellow Spring .3 Bar, 4.35 PSI
looks like u have the small yellow spring which is 4.35 psi. Maxing out your boost controller i dont think you'll be able to hit 15psi.
Old May 4, 2004 | 12:05 PM
Hoosier Daddy's Avatar
Default Re: tial wg 38mm spring..help.. (SpoolnG2)
Not to jack your thread, but I never knew there was a "maximum" psi you can boost with springs. I thought they were only for the minimum. Anyone know how much I can boost with a .5psi spring?
Old May 4, 2004 | 12:07 PM
b18bturbo's Avatar
Default Re: tial wg 38mm spring..help.. (Hoosier Daddy)
you should be able to double your spring pressure after that its not gonna work that well.
Old May 4, 2004 | 12:14 PM
jure's Avatar
Default Re: tial wg 38mm spring..help.. (b18bturbo)
damn
What spring do you recommend me for boosting around 15 psi, and where to buy this ******* spring..I'm angry cause I'm from Europe..
Old May 4, 2004 | 12:17 PM
b18bturbo's Avatar
try it with the yellow one first and see where you are at. If you need a spring let me know i have a few here. red blue green and big ones as well
Old May 4, 2004 | 12:34 PM
jure's Avatar
will you ship in europe?..and I how much costs shipping with express mail delivery like fedex, dhl to europe..
and another question, how much psi can handle greddy type S bow?
Modified by jure at 9:49 PM 5/4/2004
Old May 4, 2004 | 01:24 PM
turbo*s2k's Avatar
I read somewhere that to get your wastegate max spring pressure you multiply it by 2, and add half of that.
So if you have 5 psi spring. Max spring pressure would be 15 psi... Can anybody confirm this?
Old May 4, 2004 | 01:52 PM
So if I have a .5 bar spring, even with a MBC I can't boost much more than 1bar?
Old May 4, 2004 | 02:07 PM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy &raquo;</TD></TR><TR><TD CLASS="quote">So if I have a .5 bar spring, even with a MBC I can't boost much more than 1bar? </TD></TR></TABLE>
Well if what I read, and posted is correct then yes you can NOT boost more then one bar with that spring...
Old May 5, 2004 | 08:47 AM
ffgeon's Avatar
40mm TiAL
.25 bar / 3.63psi / small yellow
.4 bar / 5.80psi / small red
.5 bar / 7.25psi / small green
.6 bar / 8.70psi small blue
.7 bar / 10.15psi / big yellow
.8 bar / 11.60psi / big red
.9 bar / 13.05psi / big green
1.0 bar /14.50psi / big blue
Old May 5, 2004 | 09:15 AM
FwdCivicHatch's Avatar
Default Re: tial wg 38mm spring..help.. (TurboChrgd_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">I read somewhere that to get your wastegate max spring pressure you multiply it by 2, and add half of that.
So if you have 5 psi spring. Max spring pressure would be 15 psi... Can anybody confirm this?</TD></TR></TABLE>
so then you would just multiply by 3, because half of a number multiplied by two is the number you started with.
Old May 5, 2004 | 09:30 AM
tthame1's Avatar
Default Re: tial wg 38mm spring..help.. (FwdCivicHatch)
I am pretty sure that that is a large yellow tial wg spring. That is .7 Bar (10.15 psi). That should be good for anything up to 20 psi
Take a measurement of the height of that thing and I can measure my extra one.
Modified by tthame1 at 12:50 PM 5/5/2004
Old May 5, 2004 | 09:45 AM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FwdCivicHatch &raquo;</TD></TR><TR><TD CLASS="quote">
so then you would just multiply by 3, because half of a number multiplied by two is the number you started with.</TD></TR></TABLE>
Duh! Why didn't I figure that out...
Old May 5, 2004 | 11:57 AM
jure's Avatar
Default Re: tial wg 38mm spring..help.. (tthame1)
Height of my spring is 85mm..Is big or small one?
Old May 6, 2004 | 02:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote"> TIAL Big Blue Spring 1 Bar, 14.5 PSI
How sure are you of those colors? I'm reading something different on each site. I have a Green spring, not sure if it's considered big or small. Importparts said it was a .5, and a few other sites say it's .5, but i'm reading in your post and on other sit'es that it's .65.
Old May 6, 2004 | 02:32 PM
Mr. Softee's Avatar
viren, i do not see how the wastegate spring has much to dow ith the max one can boost. I always have thought it was solely dependent on downpipe and wastegate size... Maybe max safe boost because the wastegate gets stuck open? *confused*
Modified by 94goldjungsr at 11:53 PM 5/6/2004
pcguy760
Jul 8, 2011 09:08 AM
eg:R
Mar 6, 2006 01:15 PM
gdrum
Feb 24, 2004 01:55 PM
Neukin
Aug 27, 2003 08:19 PM
