How many psi is my Tial wastegate?
I got a Tial wastegate from a friend and its brand new.
The box says that the spring is .65. I have no clue how many psi that is. Anyone know?
Re: How many psi is my Tial wastegate? (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">.65*14.7=9.555</TD></TR></TABLE> So whatcha go there is almost a 10psi spring bud
Re: (ebp 99 si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebp 99 si »</TD></TR><TR><TD CLASS="quote">well something must have been wrong w/ my tial cuz it had the .5bar spring and it would only go to 7psi and no further</TD></TR></TABLE>
I don't mean to sound like a d!ck, but are you using a boostcontroller? You'll need a boost controller to raise your boost. The wastegate will only boost to whatever the spring is, and then you can raise boost via boost controller.
Re: (youngkow)
thats what i was tryin to tell the guy that said the spring is the least amount of boost u can run,
the spring is the most u can run unless you do have a boost controller hooked up to it then you can regualte the boost to however u like but you still can't go below the spring
Re: (Foozball26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 »</TD></TR><TR><TD CLASS="quote">the easiest explanation is
10 psi is the ONLY boost level you can run UNLESS you have a boost controller to RAISE the boost.</TD></TR></TABLE>
exactly
exactly
yusoslo
07-12-2003 08:01 PM
