Bleeding Map sensors with check valve help!!! or Black BOX wiring instruction
I did a search already and couldn't find enough info. Where can I find and buy check valves, I am helping installing a greddy turbo kit for my friend. We have everything installed already, but we are stuck because the kit came with the black box. I don't know how to wire it up. No diagram. So I want to use check valves, I did a search and couldn't find any info on how to piece it together or where to get it or a wiring instructions for the black box. So can someone help me out. Thank you in advance
Guest
Posts: n/a
Re: Bleeding Map sensors with check valve help!!! or Black BOX wiring instruction (khang77642)
OK, here's the deal go to a pet store that has aquarium supplies and ask for check valves. Buy three, they're cheap only about $1-$2 a piece. Then go to the auto parts store and buy a vacum line tee. Buy one that has three coming off the side (in addition to the straight, in line input and output). Then take some extra vacuum line and put three small pieces on the tee coming off the side. Put the check valves on the end of these three pieces so they blow air out but can't suck air in. Then splice the input and output into you're MAP sensor vacuum line.
nah man run the black box, the car will run way better and have better throttle response ill dig up the wiring info.
Rob03Pro5
07-25-2001 08:37 PM
