best setup for turbo b16a t3/t4 garrett
Old 07-20-2009, 01:06 PM
Hatcheys314's Avatar
Icon6 best setup for turbo b16a t3/t4 garrett
i have a 95 civic dx hatchback with a b16a with a fully built head
what is the best compression to use?
Old 07-20-2009, 01:46 PM
roadsqueegy95's Avatar
Default Re: best setup for turbo b16a t3/t4 garrett
most ppl usually run around 9:1, but alot ppl boost on stock compression to!
Old 07-20-2009, 01:59 PM
how many psi for 9:1?
What are the best
pistons?
cc injectors?
fuel rail?
Old 07-20-2009, 02:07 PM
ctr32's Avatar
whats your power goal??
Old 07-20-2009, 03:50 PM
As much hp as I can without blowing it up
Old 07-20-2009, 04:05 PM
non-VTEC's Avatar
you need to do ALOT of research......there are guys that can blow stuff up at 180whp and guys that can run 600+ safe.
pick your realistic power goal and someone MIGHT be able to help you.
Old 07-20-2009, 04:12 PM
At least 350 whp
Old 07-20-2009, 04:22 PM
non-VTEC's Avatar
how much money do you have/want to spend to reach your goal?
Old 07-20-2009, 04:47 PM
Like 2 grand but Its a slow build but would like too know the best route to take.
Old 07-20-2009, 05:54 PM
jasoncrashtech's Avatar
first off, don't use b16a cams (if you still have them)
Old 07-20-2009, 06:32 PM
I am pretty sure that I have after market cams in the head because they are powder coated black aren't the stock ones just aluminum
Old 07-20-2009, 06:33 PM
blackeg's Avatar
so what are you gonna get it tuned with/who is going to do it? dont sleep on how important the tune is.
i feel anything in the 9:1 range will do you fine
Old 07-20-2009, 06:44 PM
well i dunno about the cams, im pretty sure mine are black, but as stated before if ud get some gsr cams or ctr cams, it would help!
Old 07-20-2009, 08:20 PM
I am not sure yet but I definitely plan on getting it professionally tuned
But how many pounds of boost should I be pushing on boost 9:1
Compression on a stock b16a block?
Old 07-20-2009, 08:24 PM
Moderator
TheShodan's Avatar
don't worry about that so much. just get the car tuned. the number of psi of boost will come on day of tune. It depends upon the T3/T4 you have.
Old 07-20-2009, 09:56 PM
Its a Garrett t3/t4
Old 07-20-2009, 10:58 PM
project dc2's Avatar
that doenst say anything
theres diffrent trims/ wheel sizes
Old 07-21-2009, 06:12 AM
I'm almost positive its a 67 trim....
Old 07-21-2009, 02:41 PM
Tony the Tiger's Avatar
Its a Garrett t3/t4
No kidding...
Trim, turbine housing A/R, exhaust wheel trim, etc..
Old 07-21-2009, 03:04 PM
jv88_dc2's Avatar
most likely a 57 trim you mean? i think 550cc injectors, healthy motor, and a good tune, you should make close, if not, 350whp. But Tune is a BIG deal when it comes to boosting. Choose your tuner wisely and talk to him ahead of time and ask him what he recommends and see what program he feels comfortable tuning with is your best bet.
Im in the process of boosting my stock gsr, here are are my specs if theyre any help.
Turbonetics t62-1 ball-bearing turbo
Cheap XS Power engineering Manifold
Turbonetics Evolution 38mm Wastegate
3in Downpipe with an electronic cutout after
2.5 piping from turbo to IC and IC to Throttle body
Greddy BOV
DSM Evo injectors which are 550cc
Walbro 225 fuel pump
AEM Fuel Rail
ARP headstuds
Dual ValveSprings and Retainers
PLanning to tune with Crome
Id say if you wanted to keep the motor stock internally, get headstuds, replace the headgasket while youre at it (Pros still just use OEM gaskets on their builds), and you should be fine to boost.
But I cant stress how important a good tune is!
Old 07-22-2009, 05:19 AM
Greddy BOV
AEM Fuel Rail
ARP headstuds
Thanks the info is very much appreciated the only thing that is really
Stock is the block but I'm probably going to get it sleeved just so it can be fresh I'm still not sure on what pistons would be best any ideas?
JDMSir24
04-09-2010 07:15 AM
JDMSir24
Engine Management and Tuning
04-04-2010 01:26 PM
Hatcheys314
07-20-2009 12:39 PM
VTI Brazil
09-27-2005 06:43 AM
bnut510
09-15-2005 11:02 AM
Quick Reply: best setup for turbo b16a t3/t4 garrett
