B20B and Uberdata Tuning Questions...
Old Dec 13, 2004 | 03:07 PM
The Destroyer's Avatar
Default B20B and Uberdata Tuning Questions...
Alright guys (b20 turbo guys) I have a few questions regarding B20's and boost and keeping it safe.
I plan on retarding it 1 degree per lb, now should this be fine with stock timing?
Since it will be tuned with uberdata we are going to get it into the low/mid 12 afr ranges. Im sure this will be fine but I want to hear peoples stories.
Im only going to be running 5-6 PSI on a t3t4. If it makes it better I live in FL so I can get 93 octane at almost any station.
Thanks in advance,
Eric
Old Dec 13, 2004 | 04:36 PM
93turbo16's Avatar
uberdata forum..
Old Dec 13, 2004 | 04:55 PM
UberTeg's Avatar
Default Re: B20B and Uberdata Tuning Questions... (Vtaaak y0)
where are you in fl? anywhere near tampa?
Old Dec 13, 2004 | 05:12 PM
mtber's Avatar
If you don't feel confident tuning it yourself... Go to TitanMotorSports in Orlando and have Darin tune your setup.
Old Dec 13, 2004 | 05:39 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtaaak y0 &raquo;</TD></TR><TR><TD CLASS="quote">
1 degree per lb is very conservative, but ok I guess. For less then 10psi you can do .9 and still be conservative on the tune. I would shoot in the higher 11's for AFR. Why try to squeeze out 5-6 WHP when you can just turn up a little more boost say (1PSI) and run it in a much safer 11.2-11.7 AFR. Many tuners I speak with say this is the smarter way to go. Since your running uberdata you can do more then 5-6 PSI and be perfectly safe. You seem to be ok on timing and as long as the AFR's stay in the range like I said, and you could run 7-8 safely, maybe even more.
Old Dec 13, 2004 | 05:58 PM
blackeg's Avatar
Default Re: B20B and Uberdata Tuning Questions... (adseguy)
personally i would do like .9 per pound and go a little richer, shooting for like 11.7-12.0:1 a/f. whenever i try and tune for boost with uberdata, i go for about 11.8 or so.
Old Dec 13, 2004 | 06:06 PM
JDMs1eeper's Avatar
I ran 8-10psi on my b20 for a long time on just a FMU setup. and before that i sprayed a 85jet and 100jet of nitrous like candy for years. You should be pleny fine w/ uberdata and 7psi. Good Luck
Old Dec 13, 2004 | 06:31 PM
UberTeg's Avatar
Default Re: (mtber)
darin pwnz uberduhta!!!!
Old Dec 13, 2004 | 07:18 PM
T-RO's Avatar
W00t! for Florida... lol
Old Dec 14, 2004 | 11:21 AM
Default Re: B20B and Uberdata Tuning Questions... (UberTeg)
I am 2 hours south of Tampa.
My friend is coming over to tune it.
Thank you.
T9U4ReBgO
Feb 4, 2008 04:13 PM
turbo boost
Oct 24, 2007 10:44 AM
wfocrx
Apr 12, 2007 01:14 PM
machine4321
Oct 22, 2006 02:17 PM
dwilson
Jan 28, 2003 03:32 PM
