B18B Smoking Problem HELP!!
Old Jul 12, 2004 | 10:18 PM
Spoolin18's Avatar
Default B18B Smoking Problem HELP!!
I have a 95 B18B equipped with a Garrett T04B T4 running 5 psi. The car throws white smoke..a good amount of it at times. My oil return line has a pretty good kink in it and goes down into a C pretty much and then comes back up a little to run into the oil pan. Do you guys think that this could be causing that huge problem or do you think its something a little more serious. I will try and post a picture of the oil return line tomorrow and you guys can see for yourself Thanks a lot.
Old Jul 13, 2004 | 01:02 PM
alfee's Avatar
Default Re: B18B Smoking Problem HELP!! (Spoolin18)
if you gas it and white smoke comes out, its better than white smoke comin' out just when you start the car. check your pipes ie: dp/charge pipes to see if you have oil in them, that could be a prob too. other than that it should be fine if you gas it and white smoke comes out, it should go away after a few days of driving.
Old Jul 13, 2004 | 01:08 PM
PTR1's Avatar
Default Re: B18B Smoking Problem HELP!! (alfee)
is your oil return line, don't waste your time posting the pictures. The line should be as free flowing as possible, NO KINKS at all.
Old Jul 13, 2004 | 01:12 PM
alfee's Avatar
Default Re: B18B Smoking Problem HELP!! (VIMPORT.COM)
yeah i had that prob too early on and the oil pressure busted my turbo seals..sux, then i switched to a 3/4" (thumb size) return line for better flow.
Old Jul 13, 2004 | 06:11 PM
Spoolin18's Avatar
Thanks a lot guys...that's what i thought it was i just wanted to get a few more opinions...they always help out
Old Jul 13, 2004 | 08:02 PM
riceburnah's Avatar
I had tons of white smoke pouring out the exhaust when I just started the car shortly after the turbo install. Turns out my pistons were gone so I bought a built motor and it was still smoking white and idealing rough I believe my turbo is done too it sux. I think I tapped the pan wrong because it sits in the middle(too low) and its angled up a bit. I think it caused oil pressure and blew the seals to my new turbo. All in under an hour.
big-cat
Jun 21, 2007 06:09 AM
RotiEatter
May 21, 2005 10:12 AM
specv5150
Jun 8, 2004 03:36 PM
NateTEG95
Oct 7, 2003 03:20 PM
EJ1B20B
Mar 27, 2002 05:29 PM
