Possible causes for white/grey smoke.
Old Oct 5, 2003 | 08:36 PM
NateTEG95's Avatar
Default Possible causes for white/grey smoke.
Ok, I'm blowing white/grey smoke when I run at WOT.
I've searched, but I don't seem to have the problems eveyrone else with white smoke has.
<u>I don't have:</u>
Oil in my charge pipes
Oil in my compressor housing
Low compression (~240 all the way accross)
A catch can (maybe I need one?)
No coolant in oil or vice versa
A steel braided oil return. It's not crimped by any means, bent as much as one would expect with a non-braided line.
I do, however, have an oil leak that drips on my exhaust from time to time. Is this the cause? Would that not cause it to burn the oil off all the time, rather than just at WOT? FWIW, I'm running an FMU and inline pump. Where's the smoke coming from???
Old Oct 5, 2003 | 08:41 PM
civic dx's Avatar
Default Re: Possible causes for white/grey smoke. (NateTEG95)
running rich mine dose it also.
Old Oct 5, 2003 | 08:44 PM
AlphaKennyWun's Avatar
if oil is falling on your exhaust then it cant be coming out of it.
Its probably the turbo seals starting to go bad but if they are in good condition, then it could be the oil not draining from turbo fast enough.
Try checking for play in the turbo shaft.
Old Oct 5, 2003 | 09:00 PM
Tofurky's Avatar
I have the same problem as you.
It's either...
Turbo seals.
Valve seals.
Piston rings.
Or some random seal somewhere.
Good luck. I'm gonna to investigate my turbo. Then check the head. And if nothing's found, then I'll have to pull the block.
Old Oct 6, 2003 | 07:30 AM
NateTEG95's Avatar
Default Re: Possible causes for white/grey smoke. (S03Burner)
Pretty sure it's not my pistons rings, as I would have low compression, right? I mean come on, 240 accross is decent even for 10.6:1, right? Same with valve seals.
If my turbo seals were bad, wouldn't it blow smoke all the time?
Old Oct 6, 2003 | 08:24 PM
Tofurky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NateTEG95 &raquo;</TD></TR><TR><TD CLASS="quote">Pretty sure it's not my pistons rings, as I would have low compression, right? I mean come on, 240 accross is decent even for 10.6:1, right? Same with valve seals.
If my turbo seals were bad, wouldn't it blow smoke all the time?</TD></TR></TABLE>
i said the same thing. check out my thread....
https://honda-tech.com/zerothread?id=620198
Old Oct 7, 2003 | 03:20 PM
NateTEG95's Avatar
Default Re: Possible causes for white/grey smoke. (Tofurky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tofurky &raquo;</TD></TR><TR><TD CLASS="quote">i said the same thing. check out my thread....</TD></TR></TABLE>
Did you ever figure out a definitive answer? The oil level may be something to look at, I'll definatley check it out.
Andrew99911
Honda Civic (2001 - 2005)
Jul 5, 2017 11:46 AM
GReddy_Civic
Aug 11, 2008 11:42 AM
big-cat
Jun 21, 2007 06:09 AM
dynomax27
Nov 1, 2002 02:40 PM
sushibug
May 29, 2002 03:52 PM
