axle question
Old Apr 14, 2002 | 10:18 PM
sweettooth's Avatar
Default axle question
How much HP can stoke axles take before they break. I am not going to be running slicks. I have a quaife LSD if that matters, not sure.
Old Apr 14, 2002 | 10:42 PM
dubster99's Avatar
Default Re: axle question (sweettooth)
It depends on how hard you drive them. Hard launches and shifting can snap them easily with a high power car, and a stiff clutch.
Old Apr 15, 2002 | 12:29 AM
sweettooth's Avatar
Default Re: axle question (dubster99)
should i just get driveshaft shop axles to be safe?
Old Apr 15, 2002 | 02:49 AM
The Punisher's Avatar
Don't buy too quickly, Viren is about to post a GB for the driveshaft axles!
Old Apr 15, 2002 | 06:40 AM
1's Avatar
Default Re: axle question (gsr*lude)
How is everyone with high h.p. cars fortifying their trannies if they are upgrading to these stage 3
axles? Seems cheaper to bust axles than trannies.
Old Apr 15, 2002 | 09:51 AM
sweettooth's Avatar
Default Re: axle question (1)
Which stage axles should I buy for at most 400whp. Just wonna be safe.
Old Apr 15, 2002 | 01:55 PM
Stage 3, up to 500 whp
Old Apr 16, 2002 | 06:40 AM
Dublocivic's Avatar
Usually its the diff that goes in stock Honda trans 1st. If you use a Quaife, KAAZ, Cusco etc it will either spin the clutch or break a mainshaft/countershaft in the tranny... I honestly have not seen to many main or counters break in the newer trannys... stock Honda trannys are pretty damn impressive if you ask me. If you control your launch on the slicks ie: NOT DUMPING THE CLUTCH.. you hit that "sweet" spot on the clutch where its grabbing but not with a bang. Stuff should hold together pretty good, but it takes lots of practice.
To add to this.. I would rather have my trans break half way down the track than an axle.. it takes you a second to realize what has just happened when you break and axle. I dont want to be looking at a wall at over 120mph if it decides to break then. Most of the time if your trans breaks the car still goes straight... and its a bit more predictable.
[Modified by Dublocivic, 4:20 PM 4/16/2002]
[Modified by Dublocivic, 4:21 PM 4/16/2002]
[Modified by Dublocivic, 6:02 PM 4/16/2002]
Old Apr 16, 2002 | 10:41 AM
sweettooth's Avatar
Default Re: axle question (Dublocivic)
When is the groupbuy for axles?
[Modified by sweettooth, 7:48 PM 4/16/2002]
Old Apr 16, 2002 | 10:48 AM
Spocko's Avatar
I was about to buy the new solid stage 2 axles from them, but I think I will wait until the GB for them- they were $269 a piece and he said that they could handle the 400-450 wheel hp nicely, especially with a LSD(which I have)
Please someone post up a link when the buy goes down!
Old Apr 18, 2002 | 06:13 AM
Default Re: axle question (Spocko)
https://honda-tech.com/zerothread?id=166302 Here is the groupbuy info.
Flexin5
Sep 15, 2006 03:08 AM
95c1v1cs1
Feb 12, 2003 07:59 PM
darkfx
Aug 23, 2002 02:31 PM
hybrid901
May 23, 2002 06:28 AM
The Punisher
Oct 16, 2001 04:44 PM
