ARP stud install...post your installation dos and donts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy »</TD></TR><TR><TD CLASS="quote">u can torque them to 63 but i would to at least 70..arp recomends 78-80 ft lbs are u using moly lube or oil..?</TD></TR></TABLE>
I kinda was thinking about maybe doing 77ft-lbs like someone recommended earlier in the post.. Whats best? Moly lube or regular motor oil?
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
ita all preffernce i use the lube though..but i know many people that use the oil too and no probs...77ft lbs will be fine with the lube..i have had no probs with 72-78 on lube..1+year running strong on my daily driver..
Sounds like a scary moment I'd be kicking myself in the ***! Nice trick with the nail and epoxy, that stuff will hold anything.
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erics99si »</TD></TR><TR><TD CLASS="quote">Anyone 100% positive on what the final torque spec is on the ARP head stud??
My method is:
double nut method putting studs into block... finger tight, then torque to 10ft-lbs... slap head on, and torque in sequence 22ft-lbs first time around, then the final (??????)..
Chiltons manual says 96+ OEM B18C5 head studs are torqued to 63ft-lbs, is this the same with the ARP's?</TD></TR></TABLE>
Here's how I torqued my ARP's.
It may be overkill, but who gives a ****?
Hand-tight to get the studs in the block.
Then when the head was on, 14 ft./lbs. in the proper sequence.
Then 20 ft./lbs.
Then 40 ft./lbs.
Then 65 ft./lbs. (using ARP lube)
Then 65 ft./lbs. again.
I have not retorqued after about 700 miles, I really should though.
*knock on wood*
My method is:
Then 20 ft./lbs.
Then 40 ft./lbs.
*knock on wood*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo »</TD></TR><TR><TD CLASS="quote">some good info in this thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi »</TD></TR><TR><TD CLASS="quote">when you guys say 70lbs tq you are talking about the nuts on top of the head right</TD></TR></TABLE>
Yes!
Yes!
