how do i install the arp head studs?
Old Jan 30, 2007 | 12:13 AM
ivt-t's Avatar
Default how do i install the arp head studs?
i bought arp studs for my b16 but no instructions received
i need know urgent what torque it needs.
thank you!!
Old Jan 30, 2007 | 05:07 AM
Topdawgg's Avatar
i cant remember off hand but i remember most guys do it in 2 stages...
usually 20 something ft/lbs
then around 40 ft/lbs..
those numbers arent correct, but just an idea
Old Jan 30, 2007 | 05:45 PM
1Bar GSR's Avatar
Default Re: (Topdawgg)
You go by the factory torque specs!
For a b18
First to 22 lbf-ft
Second to 60 lbf-ft
Tighting order is
9.5.1.3.7
8.4.2.6.10
Old Jan 30, 2007 | 06:19 PM
EK FLY's Avatar
Default Re: (1Bar GSR)
if u dont want to replace ur headgasket do it one by one l
u take 1 old headstud and install a new arp headstud and torque it do it from the middle of the head to the sides
Old Jan 30, 2007 | 06:25 PM
RedEj8's Avatar
Default Re: (super-hatch)
first off you DO NOT torque the headstuds into the block..They should come with a place at the top to put an allen wrench.And they should also have a nipple on there to keep the studs from bottoming out in the hole.Run the studs into the block with the allen wrench until it stops and make sure its all the way down. If youre using ARPs lube, put a good amount on the threads sticking out if the block, on the washers and inside the nuts. Torque to something like 20ft-lbs, then to 45 or so..then to 65ft-lbs. If youre using motor oil instead of ARPs lube, torque to 70ft-lbs. At least these are the specs for my gsr studs, should be the same tho.
Old Jan 30, 2007 | 09:24 PM
ivt-t's Avatar
Default Re: how do i install the arp head studs? (ivt-t)
i works now
thank you for help!
Old Jan 30, 2007 | 09:58 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Bar GSR &raquo;</TD></TR><TR><TD CLASS="quote">You go by the factory torque specs!
For a b18
First to 22 lbf-ft
Second to 60 lbf-ft
Tighting order is
9.5.1.3.7
8.4.2.6.10</TD></TR></TABLE>
I used golden eagle 10ft-lb into the block, then 20 40 then loosen and do it again, then torque to like 72ft-lb don't remember exactly. Either way I'm sure it's more then stock. They are stronger then stock and 60ft-lbs may not stretch them.
Old Jan 31, 2007 | 02:34 PM
1Bar GSR's Avatar
Default Re: (Mr Wonderfull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull &raquo;</TD></TR><TR><TD CLASS="quote">your a ******* idiot.
no you dont
go to ARPs site... its listed...</TD></TR></TABLE>
I love you! Fight hate with heart!
Old Jan 31, 2007 | 02:49 PM
ProJectCvic's Avatar
you arp head stud should come with a torque spec. I don't quite remember what it is now.
Old Jan 31, 2007 | 03:09 PM
katoeh2o's Avatar
So it is possible to install there without removing the head?
Old Feb 6, 2007 | 06:21 PM
borntrini's Avatar
any one knows the torque specs on a D16z6 arp head studs and the sequence?
Old Feb 6, 2007 | 06:43 PM
cuin9sec
Guest
Posts: n/a
For a b18
First to 22 lbf-ft
Second to 60 lbf-ft
Tighting order is
9.5.1.3.7
instructions will come with the studs...should anyways. just wait.
Old Feb 6, 2007 | 07:09 PM
nihad's Avatar
Default Re: how do i install the arp head studs? (borntrini)
jr... go search d16z6 head torque spec and you will find it even for the arp.
its like 15 pounds over stock so it would be 65 pounds
Old Feb 8, 2007 | 06:14 PM
borntrini's Avatar
anyone know the tighten sequence
of a D16Z6
Old Feb 8, 2007 | 09:15 PM
ABK's Avatar
ABK
Default Re: (borntrini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by borntrini &raquo;</TD></TR><TR><TD CLASS="quote">anyone know the tighten sequence
of a D16Z6</TD></TR></TABLE>
http://media.honda.co.uk/car/o...4.pdf
here you got but search first next time
Kr4nG
Nov 6, 2009 02:48 AM
95_red_dc
Aug 31, 2008 06:17 PM
95_red_dc
Aug 31, 2008 09:28 AM
S2KBAR
Mar 9, 2005 08:44 AM
LudEcrous
May 4, 2004 01:47 PM
