How much am i going to gain with a bigger exhaust?
How much am i going to gain with a bigger exhaust and downpipe?
This is my dynorun.
Integra GSR 97 @ 7.75 psi. intercooled. I know it's not much, i did no tuning at at all. I use the 2" downpipe, no cat, and 2.25" DC sports catback exhaust. I plan on upgrading the exhaust to 3" front to back , but about how much hp can I expect to gain?
[Modified by meanteg, 6:42 AM 12/8/2001]
Re: How much am i going to gain with a bigger exhaust and downpipe? (meanteg)
When I upgraded from a 2.5" to 3" all the way from the downpipe back, I pick up another 10 whp. Now at 7.5psi I dynoed at 266whp then 277whp after upgrade. My torque also went up from 190ft/lbs to 200ft/lbs. Expect alot.
Dont forget when I dynoed the 2nd time it was also 104 deg here in texas so I expect to get alot more now that is much cooler here.
art
art
New User
I'm assumig you are o a greddy kit cuz ofthe numbers ya got? If so first thing to do get rid of the 2" twig and replace with a 2.5" after the elbow piece. Get it fabricated at a muffler shop. I dynoed my greddy kit at 7.8 psi or 7.5 as well same **** really with just the downpipe upgrade and with an HKS hyper **** which is only 2.1" and got 214 hp and 165 tq to the wheels. So I know there should be a definite gain going to a 3".. DO IT!!I am hoping to see a 20hp gain to the motor ..again hopefully
[Modified by boost killz, 11:00 PM 12/7/2001]
Is your w/g dump routed back into the downpipe or is it vented to atomsphere. What else do you have, give us your setup. Seems to be more than just exhaust.
Re: How much am i going to gain with a bigger exhaust and downpipe? (Slow_ass_4dr)
I use the internal wastegate.
-Stock 97 GSR
-Greddy turbo kit
-Greddy fcu ( blue box)
-Holley 255 lph in tank fuel pump
-2" downpipe
-no cat
-DC 2.25" catback exhaust.
That's all for the engine.
I took my compression today and I found why I was not producing as much power as I was supposed to, cylinder 1 has 125 pounds, ans cylinder 3 has 115 pounds. The engine has overheated because of a defect of the thermostat.
-Stock 97 GSR
-Greddy turbo kit
-2" downpipe
-no cat
well, the low comp readings certainly will not help ur hp readings...sorry to hear.
also, greddy kits are notorious for their less than desirable hp readings on a gsr when compared to other kits.
Tom
Tom
Re: How much am i going to gain with a bigger exhaust and downpipe? (Tomakit)
[Modified by meanteg, 3:57 AM 12/9/2001]
greddy turbo isn't as big (read: doesn't flow as well) as the drag3 turbo's.
greddy downpipe is tiny, cause its meant to be used with the stock cat.
Tom
Tom
damn that is some low compression for a gsr .. I hope you aren't running stock pistons and it's giving you that... besides that even if you were like 9.0:1 I don't think compression would be that low..
New User
wow, i didnt know greddy kits produced that much less numbers, im looking for about 230 whp at 8 psi in my ls once i go from 2.5" to 3" exhuast. getting a bigger downpipe and 3" inch exhuast should help a lot though since thats a big downside to it.
Re: How much am i going to gain with a bigger exhaust and downpipe? (chuckd05)
Re: How much am i going to gain with a bigger exhaust and downpipe? (bodykit=rice)
i dont get why with a bigger dump pipe u can get more hp ???
i got TiAL 36mm , how big should the dump pipe be ?
thanks
thanks
