Anyone using AEBS head studs??
Old Aug 12, 2003 | 04:37 PM
  #26
Code Blue's Avatar
Default Re:
you think they will make them for the non vtec engines or will it only be for vtec heads?
Old Aug 13, 2003 | 05:30 AM
  #27
93LSivic's Avatar
Default Re: Re: (Code Blue)
Well I ordered them yesterday guys. I hope they work out well. I wanted to splurge and get the main's too, but I'm going to have to let off for now. I just want to get my car back on the road I wont even bae able to beat on it til the new CM stage4 breaks in either
Old Aug 13, 2003 | 08:26 AM
  #28
baphomet's Avatar
Default Re: (93LSivic)
Nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">Oh, and BTW B3435. I have seen their sleeves. This is why Darton changed their design a couple of times......actually improved on it a couple times.
This here is my personal Darton block (which is gonna get the vtec head treatment using the AEBS studs) with the MOD1 sleeves.
Old Aug 13, 2003 | 12:20 PM
  #29
Rob Dizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Code Blue &raquo;</TD></TR><TR><TD CLASS="quote">you think they will make them for the non vtec engines or will it only be for vtec heads?</TD></TR></TABLE>
I called up aebs today regarding the ls stuff. no luv though for b18b
just get some arp studs if you have an ls
Old Aug 22, 2003 | 03:35 PM
  #30
ExospeedAMcrx's Avatar
Default Re: Re: (Bob-DC2)
Here's some pics of the AEBS head studs.
H22 and B18C in stock.
Old Aug 22, 2003 | 03:40 PM
  #31
LsTurbo91's Avatar
Default Re: (Boostfed)
I nominate Boostedfed to be a Golden Eagle spokesperson
Old Aug 22, 2003 | 05:53 PM
  #32
T4eg's Avatar
Default Re: Re: (exospeedAMcrx)
the AEBS head studs are very good. Im running them
Old Aug 23, 2003 | 11:19 AM
  #33
Bnjmn's Avatar
Default Re: Re: (BlueHatch00)
Does anyone know what torque specs AEBS recommends?
Old Aug 23, 2003 | 12:00 PM
  #34
Turbo R's Avatar
Default Re: Re: (Bnjmn)
70 ft lbs
Old Aug 23, 2003 | 12:49 PM
  #35
Bnjmn's Avatar
Default Re: Re: (Turbo R)
Thanks- is that using motor oil or something else?
Old Aug 23, 2003 | 01:04 PM
  #36
Turbo R's Avatar
70 ft lbs for B18C. Yes use motor oil.
Old Sep 2, 2003 | 10:56 PM
  #37
mskibbz-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
Dammit, after reading this thread I was going to pick up a set of AEBS studs for my LS... I guess not
Old Sep 2, 2003 | 11:17 PM
  #38
Default Re: Re: (mskibbz-T)
yup... we carry AEBS studs and only avail for H22, B18C, and B16A
Old Sep 3, 2003 | 02:51 AM
  #39
DSF's Avatar
DSF
Default Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">
Im far from an engineer but I cant see how motors that are sleeved like that can even cool themselves. The water jacket capacity is reduced by like 90%. How does the engine NOT have major overheating problems with hot spots?</TD></TR></TABLE>
Like others have said, it's not a real big concern. Why? Ever looked at a headgasket? Notice how there are only small holes around the water jacket?
Old Sep 3, 2003 | 07:03 AM
  #40
93LSivic's Avatar
Default Re: (DSF)
The sleeves dont take up 90% of the cooling jacket. The closed deck is only .75" if I remember correctly.
Anyways. I got my AEBS studs yesterday. Super nice!! I will be assembling this week and hopefully have the car back on the road next week sometime.
Old Sep 3, 2003 | 08:33 AM
  #41
AVRturbodout's Avatar
These blocks have no issues whatsoever with cooling. This is common misconception. You will have more of a cooling issue if you were to remove the shroud from around the factorey fan.</TD></TR></TABLE>
As far as daily driving with with an AEBS sleeved block, will cool ing issues come into play? Currently in the market for a daily driveable sleeved block.
Old Sep 3, 2003 | 08:40 AM
  #42
93LSivic's Avatar
Default Re: (AVRturbodout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVRturbodout &raquo;</TD></TR><TR><TD CLASS="quote">
As far as daily driving with with an AEBS sleeved block, will cool ing issues come into play? Currently in the market for a daily driveable sleeved block.</TD></TR></TABLE>
I dont think the AEBS or any closed deck blocks would have cooling issues. THIS IS A COMMON MISCONCEPTION! This **** got spread around years ago by people who purchased block gaurds (then got dragged into sleeves) that were not drilled properly and did not line up with head gasket coolant jacket holes thus causing cooling problems.
My personal sleeves are the old design, or same as AEBS current design.....and again for the umteenth time, I have never had cooling issues even using my stock sohc single core civic radiator with stock fan and LS water pump.
Old Sep 3, 2003 | 11:43 AM
  #43
Code Blue's Avatar
so if i plan on going ls vtec i should get the studs that correspond with the head. correct?
rdeezy78
Apr 18, 2007 09:06 PM
IntegraMark
Feb 28, 2007 06:12 AM
vtec-gorilla
Dec 1, 2006 05:46 PM
markvqwerty
Oct 19, 2004 08:12 AM
BumpinVTEC
Oct 3, 2003 10:58 AM
