Head and main studs??
Old Apr 14, 2007 | 05:18 PM
rdeezy78's Avatar
Default Head and main studs??
Will it matter if I use ARP main studs and GE head studs? I'm getting a good price on these new and was curious if it would matter. Plan to run around 20 psi of boost. Forged internals, FYI. Thanks for any input before I purchase either kits.
Old Apr 14, 2007 | 05:39 PM
unknown0001's Avatar
Default Re: Head and main studs?? (rdeezy78)
as long as they aren't mix-matched...ex: using ARP and GE head studs together.
If you use ARP mains and GE head studs then I'm sure with proper TQ specs it will hold just fine
Old Apr 14, 2007 | 05:40 PM
rdeezy78's Avatar
Default Re: Head and main studs?? (Mr.RHTuner)
cool. thanks for the input
Old Apr 14, 2007 | 06:10 PM
Muckman's Avatar
Moderator in Chief
It will instantly explode if you mix and match fastner brands. Don't do it!
Old Apr 14, 2007 | 07:13 PM
zexxbo's Avatar
Default Re: Head and main studs?? (Muckman)
im curious to know these good prices. i can get aebs head and mainstuds for $120/each
Old Apr 15, 2007 | 05:27 PM
rdeezy78's Avatar
Default Re: Head and main studs?? (zeimbo)
I'll be sure to pas the link once I purchase mines. They only have 4 in stock. Still waiting on some more opinions on the mix of studs? I will post them Monday night.
Old Apr 15, 2007 | 05:46 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdeezy78 &raquo;</TD></TR><TR><TD CLASS="quote">I'll be sure to pas the link once I purchase mines. They only have 4 in stock. Still waiting on some more opinions on the mix of studs? I will post them Monday night.</TD></TR></TABLE>
Simple, dont mix.
Run ARP's or GE's. That's it.
Old Apr 15, 2007 | 07:01 PM
urbansi's Avatar
Default Re: Head and main studs?? (1995Civic)
Dont you have to line bore your mains when switching to main studs?
I have heard something along the lines of that...
Old Apr 15, 2007 | 07:21 PM
Muckman's Avatar
Moderator in Chief
Default Re: Head and main studs?? (urbansi)
That is correct. The stronger clamping force of the studs will affect the tunnel bore.
Old Apr 15, 2007 | 07:46 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">That is correct. The stronger clamping force of the studs will affect the tunnel bore.</TD></TR></TABLE>
X2
Old Apr 16, 2007 | 01:34 PM
rdeezy78's Avatar
good to know. Thanks guys.
Old Apr 16, 2007 | 01:40 PM
PHDZINE's Avatar
You can also keep your stock main bolts as well....there are alot of people out there that are making a **** load of power with stock main bolts. As for the head studs...they should be changed.
The clamping force does not change if you use main studs. You torque ARP/GE main studs to stock specs....so there is no extra force holding down your main caps. They just hold the main-caps down better due to the stronger material not stretching (Studs). You will get mixed review on line boring your mains...some people do it, some don't...I personally don't.
Old Apr 17, 2007 | 04:20 PM
rdeezy78's Avatar
Default Re: Head and main studs?? (PHDZINE)
well put. Thanks
Old Apr 18, 2007 | 09:06 PM
Muckman's Avatar
Moderator in Chief
No there is a stronger clamping force with a stud bc when you torque a bolt to # number of ft/lbs a portion of that measured resistance is due to the drag of the threads along the entire shank. You dont have that with a stud. So if you torque a stud to the same value it will have a stronger clamping force. 50ft/lbs on a stud &gt; 50 ft/lbs on a bolt.
PhrequenC
Jun 9, 2008 10:55 AM
Antilag
Oct 28, 2007 12:33 AM
kornerk12
Feb 7, 2007 09:03 PM
the.hamburglar
Nov 12, 2005 07:32 PM
paulzy
Jan 5, 2003 12:19 AM
