Anyone running a boosted 82mm stock sleeve motor?
Lets see your setup. What are you numbers?
I just dropped a valve on my 81.5mm bore and need to go to 82mm now. I now its not the norm but I want to see if anyone is doing it.
Re: Anyone running a boosted 82mm stock sleeve motor? (sq_creations)
how much meat is left on the stock sleeves? they are, as i'm sure you know, made of two metals not one like replacement sleeves.. . . .
82mm is too thin for boost... Hence the reason I'm pulling my 82mm all-motor setup to build the stock 81mm block I bought...
82mm = Great for All motor...
Re: Anyone running a boosted 82mm stock sleeve motor? (White Smoke)
I know its not a good Idea. I was just wondering if anyone was. thanks for the responses. Im at the point were im gonna pick up another cheap block or save up for a year and do a sleeved block.
