safc hack
Old Jun 29, 2002 | 01:10 PM
vtecsiqt's Avatar
Default safc hack
how am i able to run 15 psi on a ls safc hack and not throw a code? also lately my car seems to be breaking up when i accelerate from about 3k to 5k then it is gone, it seems like it is misfiring or something, i have safc hack, 255 lph pump, 440cc injectors. this is screwy.....my safc says i am boosting at 10.5psi/.74kg...but my boost guage says 15psi, the dyno also said 15psi????
Old Jun 29, 2002 | 01:41 PM
Smashback's Avatar
Default Re: safc hack (vtecsiqt)
Because the word on the street is the Honda MAP is only able to handle 10-11 PSI before the element is destroyed. They say the AFC deal is only good to about 10 PSI.
Old Jun 29, 2002 | 01:45 PM
rioninja's Avatar
because your not running 15psi, your autometer gauge is reading a couple psi high (i'm making an educated guess that its autometer).
Your only running 10.5psi of boost. And, i wouldnt run run much more than that due to the limitations of the stock map sensor. Here is a simple way to figure out your actual boost reading.
Take the reading from the vafc in kg/cm2 (in your case .74)
Divide that by .070307
presto! actual boost level.
ie: vafc reading / .070307 = boost level in psi
I personally do not even have a boost gauge. I just leave the vafc in analog readout mode displaying pressure, and usually rpms.
Old Jun 29, 2002 | 04:17 PM
vtecsiqt's Avatar
Default Re: safc hack (RioNinja)
so why did my dyno read out 14.3 psi with their electronic guage hooked up and how the hell would i get 303 whp w/ a 160k motor w/ only 10.5 psi....safc is wrong
Old Jun 30, 2002 | 09:19 PM
H22coupe's Avatar
I'm running the SAFC hack on my GSR with JRSC, according to the SAFC I'm only hitting 2.8 PSI (.2 kg/cm^2) but my autometer boost gage is reading just over 6 psi. I'm only running the stock pulleys which should put me at 6 psi, so I'm not sure what the story is with the SAFC boost reading, anyone have any ideas?
Old Jun 30, 2002 | 09:43 PM
rioninja's Avatar
switch out your map with a known good one, and check to see what the afc reads then. mplex could be right, bad map.
99lspwr
Oct 24, 2003 09:12 AM
_Endless_
May 19, 2003 08:33 AM
turboegg
May 2, 2003 04:32 AM
Smashback
Apr 15, 2002 12:08 PM
willyboyK20
Mar 14, 2002 05:43 AM
