is 60mm exhaust too restricting for low psi?
searched, and couldnt find anything. i know its out there, but i dont think i used the right combo of words. but anyways, is a 60 mm piping diameter with straight through muffler too restrictive for 6-8 psi on a d16y8? i plan on buying the greddy 18g turbo kit. link me if you have the correct places, or post your thoughts please
Re: is 60mm exhaust too restricting for low psi? (slowEJ8)
It wouldnt be my first choice depending on your priorities. If you dont mind a large exhaust and you wont run into any spiking issues you definitely should upgrade.
I love my Apex'i RS, 60mm with chambered muffler, and didnt bother to switch it out. Running 2.5"dp to 2.5"TP to the RS, and I made 248/174 @ 7PSI. Probably could have made more with a different exhaust setup, but judging by those #'s I'm not too far off of similar setups with larger exhausts. Except for those freak motors making 270+ @7PSI!
Re: is 60mm exhaust too restricting for low psi? (newgsrdriver)
well i really want the rsr exmag right now, but im just wondering if itll be enough of a bottleneck when i put on the turbo to matter.
I made 323 whp at 10 psi going through 2.25" exhaust with no cat and 3" dp. B series LSvtec though.
