3 bar map sensor problem car shuts off
Old Jul 13, 2004 | 05:53 AM
zbower7's Avatar
Default 3 bar map sensor problem car shuts off
i just hooked up the map sensor. never used a volt meter so not sure how to use it. but when i start the car it starts and then just shuts right back off. not sure whats wrong just don't understand
help
Old Jul 13, 2004 | 06:37 AM
Rod.'s Avatar
Default Re: 3 bar map sensor problem car shuts off (zbower7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zbower7 &raquo;</TD></TR><TR><TD CLASS="quote"> never used a volt meter so not sure how to use it. help</TD></TR></TABLE>
this might be it right there
Old Jul 13, 2004 | 06:38 AM
underpressure02's Avatar
What ecu are you running? Did you make the proper changes in your ecu?
Old Jul 13, 2004 | 06:44 AM
shermanyang's Avatar
Default Re: 3 bar map sensor problem car shuts off (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">What ecu are you running? Did you make the proper changes in your ecu?</TD></TR></TABLE>
exactly what i was trying to squeeze out of him when he posted in the integra forum.
what standalone are you using, why are you running a 3 bar, did you install the wires correctly, etc, etc....his question is TOO BROAD.
Old Jul 13, 2004 | 07:08 AM
zbower7's Avatar
i have a integra ls that is chipped with hondata and is set up with the boost option. i am running a t3 turbo with 550 injectors and the hondata is set up with a base map 5lb boost cut and is running my 550 injectors does the hondata have to be programed to run a 3 bar map to make it work. i don't understand help
Old Jul 13, 2004 | 07:17 AM
hoggy's Avatar
The hondata will have to be set up for a 3 bar map sensor. Your problem could be that you installed it incorrectly or maybe you did intall it correctly and it won't run because of the hondata not being set up for it. There is an installation guide for a 3 bar sensor on hondata.com
Old Jul 13, 2004 | 07:25 AM
zbower7's Avatar
Default Re: 3 bar map sensor problem car shuts off (hoggy)
yea i put it on as far as i know correctly i just wasn't sure if the hondata has to get set up to run a 3 bar it or if it will run off what it has
i mean it would just start up and the shut right back off it was werid
Old Jul 13, 2004 | 07:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoggy &raquo;</TD></TR><TR><TD CLASS="quote">The hondata will have to be set up for a 3 bar map sensor. Your problem could be that you installed it incorrectly or maybe you did intall it correctly and it won't run because of the hondata not being set up for it. There is an installation guide for a 3 bar sensor on hondata.com</TD></TR></TABLE>
Old Jul 13, 2004 | 10:20 AM
Devine's Avatar
Default Re: 3 bar map sensor problem car shuts off (shermanyang)
you may still have other issues, my car started up and idled fine with a 3bar map sensor installed with a stock ecu.
boostek9
Engine Management and Tuning
Sep 7, 2008 08:43 PM
Kid_SiR
Dec 28, 2007 03:07 AM
vg7z
Sep 12, 2006 07:20 PM
Topdawgg
Jan 18, 2006 05:15 PM
The Crow
May 16, 2003 05:28 PM
