Upgrading map sensor
Old Jan 18, 2006 | 02:19 AM
Topdawgg's Avatar
Default Upgrading map sensor
Im goin from about 240 whp to around 350whp, gonna run around 1 bar of boost..
Im wonderin If it is necessicary to upgrade my map sensor
Old Jan 18, 2006 | 01:11 PM
tgreaves's Avatar
Default Re: Upgrading map sensor (Topdawgg)
Stock map sensor will do up to about 10.8psi..
Old Jan 18, 2006 | 01:13 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">Im goin from about 240 whp to around 350whp, gonna run around 1 bar of boost..
Im wonderin If it is necessicary to upgrade my map sensor</TD></TR></TABLE>
Yeah, you can get a 2.5 for cheap or just get a 3bar.
Old Jan 18, 2006 | 01:24 PM
Hybrid96EK's Avatar
Default Re: Upgrading map sensor (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Stock map sensor will do up to about 10.8psi..</TD></TR></TABLE>
11.3 max actually. I wouldn't personally push it past 10.
Old Jan 18, 2006 | 01:34 PM
tgreaves's Avatar
Default Re: Upgrading map sensor (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
11.3 max actually. I wouldn't personally push it past 10.</TD></TR></TABLE>
Opps.. The AEM EMS only works it up to 10.8, thats why I said it.. Its a 1.8bar map sensor..
Old Jan 18, 2006 | 01:36 PM
BlackCRX's Avatar
motorola 2.5bar from digikey is dirt cheap. like $20usd or something
or you can get the GM 3bar but thats alot more money
Old Jan 18, 2006 | 01:43 PM
tgreaves's Avatar
Default Re: (BlackCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackCRX &raquo;</TD></TR><TR><TD CLASS="quote">motorola 2.5bar from digikey is dirt cheap. like $20usd or something
or you can get the GM 3bar but thats alot more money</TD></TR></TABLE>
GM 3bar replica from Bosch is about $60 shipped from lightningmotorsports.com
Old Jan 18, 2006 | 04:55 PM
Topdawgg's Avatar
Default Re: (tgreaves)
are all map sensors universal, or are there honda specific ones
Old Jan 18, 2006 | 05:00 PM
93turbo16's Avatar
Most are universal with the right program to convert the voltage into something that works for the ecu/application.
You just wire it up correctly and scale your program to the map sensor you are using. If you have questions about it, just let your tuner set it up for you.
But if you do a search on a 2.5bar map sensor, there is a write up for how to install it.
I would recomend the motorolla 2.5 bar map sensor. I think it is by far one of the better map sensors out there.
Just because I like old informative posts. Go about half way down the thread.
https://honda-tech.com/zerothread?id=1266876
Old Jan 18, 2006 | 05:11 PM
Topdawgg's Avatar
would there be any problem with runnin the stock map sensor until I actually tune for the high boost..
Old Jan 18, 2006 | 05:15 PM
93turbo16's Avatar
Nope you can run the stock map sensor for up to 12 psi, if you really wanted to. You can run it on basically whatever PSI you wanted to. But it is not smart and leave no room for error, meaning mechanical error/overboosting.
kpowerdhatch
Oct 20, 2007 02:43 PM
SilverPanda
Oct 9, 2007 01:16 AM
hatchinprogress
Nov 23, 2004 08:21 PM
Kidd_Stylez
Nov 2, 2004 04:14 PM
Ej1_coupe
Feb 4, 2004 01:46 PM
