14b vs 15g
Old Apr 27, 2005 | 04:48 PM
CivicEG R's Avatar
Default 14b vs 15g
Hi
Im looking at turboing my D15 civic, and was looking at the 14b or the 15g turbo. whats the difference beteween the two, and which would you guys reccomend. I want to boost at like 7-8 lbs. and make around 180-200hp, so like 160 at the wheels.
Thanks for your help/input
Old Apr 27, 2005 | 05:29 PM
14bcoupe's Avatar
Default Re: 14b vs 15g (CivicEG R)
they are both pretty small turbos about .42/.48 basicaly size of a t3.
if i were you i go with the 14b just because they are so easy to find and pretty cheap. dsmtrader has tons of good ones. but with both you can reach 160whp no problem.
on my old d16 i made 164whp/158lbs@9psi stock exhaust/cat, with anything other than stock it would have made easy 180whp.
good luck
Old Apr 27, 2005 | 05:38 PM
Bh8teen's Avatar
The 15g is a TD04 turbine and the 14b is a td05h larger turbine. td04 spools faster but td05 holds slightly higher and longer boost.
Old Apr 27, 2005 | 05:44 PM
SOHCmaster's Avatar
14b will wax any gredy 15g set up
Old Apr 29, 2005 | 12:50 PM
CivicEG R's Avatar
thanks
Old Apr 29, 2005 | 12:53 PM
Unsivil_audio's Avatar
Default Re: (PK SPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED &raquo;</TD></TR><TR><TD CLASS="quote">14b will wax any gredy 15g set up</TD></TR></TABLE>
Agreed. 14b &gt; 15g
The 14b can almost support 300whp, whereas the 15g has problems getting over 250whp.
Old Apr 29, 2005 | 03:52 PM
sohc_vtec 2NR's Avatar
19t &gt; 14b &gt; 15g ??
Old Apr 29, 2005 | 05:22 PM
CivicEG R's Avatar
What about the 13g off the volvo 850?
What other mods will i need to support a 14g turbo, do i need new fuel injectors, spark plugs? I am gettin a new clutch in the very near future. But im just looking to see what i am gonna need to support a turbo with out any problems.
Thanks again
Old May 2, 2005 | 09:23 AM
Whats the full designation? Just remember TD05 (.48 a/r Exh) &gt; TD04 (.42 a/r Exh). And TD06 (.60 a/r Exh) &gt; TD05 (.48 a/r Exh)
98-DC4
Mar 10, 2008 05:37 PM
spoolin turbo s
Dec 2, 2007 04:24 AM
turboeg77
Sep 30, 2005 10:38 AM
Fuzion
Aug 23, 2004 08:41 AM
b18cTurbo
Jul 8, 2003 12:41 PM
