which fmu to get with dsm 450s???
Old Jun 25, 2002 | 08:23 AM
KoRE's Avatar
Default which fmu to get with dsm 450s???
OK i just installed the dsm injectors into the car last night and it's way too rich at idle so i was wondering which fmu calibration kit to get cause i have a 12:1 i think
or would i be able to get a FPR and just turn down the psi a bit?
i already have the 440s too -50 on my afc so any help would be appreciated
Old Jun 25, 2002 | 08:28 AM
VTC_CiViC's Avatar
Default Re: which fmu to get with dsm 450s??? (KoRE)
DSM 450cc injectors + 12:1 FMU =
That's ALOT of fuel, and i'm willing to bet waaaaay more than you need. Most people who switch to big injectors (440+) remove the FMU altogether. The injectors alone provide a substantial amount of fuel, you won't need to suppliment them with an FMU for a while. Ditch the FMU
EDIT: just for reference sake, I ran 12psi on my D16 with RC 440's and no FMU, and it was still rich even with -38% AFC trim
[Modified by VTC_CiViC, 12:29 PM 6/25/2002]
Old Jun 25, 2002 | 08:37 AM
RGAZ's Avatar
New User
You want no FMU.
Use a standalone or SAFC to control the fueling.
if you are hurting, try turning your fuel pressure down alot. You will be mad rich.
Randy
Old Jun 25, 2002 | 08:40 AM
KoRE's Avatar
Default Re: which fmu to get with dsm 450s??? (VTC_CiViC)
thanks for all the help i'm gonna take off the fmu and put it to -38 and see how it is there thanx
Old Jun 25, 2002 | 10:30 AM
LEON's Avatar
what kind of car do you have? Youre going to need something to control that size injector as the stock ECU is unable to!?!
Old Jun 25, 2002 | 10:46 AM
Etylorcen's Avatar
Default Re: which fmu to get with dsm 450s??? (LEON)
He says he has an afc. Im assuming you got the resistor box too.
Old Jun 25, 2002 | 11:27 AM
KoRE's Avatar
Default Re: which fmu to get with dsm 450s??? (Etylorcen)
i have a d16z6 turbo
i don't have the resistor box instead i wired 10ohm 10 watt resistors through each injector
Old Jun 25, 2002 | 12:45 PM
LEON's Avatar
and you are going to perform the "AFC hack" so that you can compensate for boost?
Old Jun 25, 2002 | 04:16 PM
DLB1994's Avatar
how much u plan on boosting
Old Jun 25, 2002 | 08:52 PM
KoRE's Avatar
i want to boost 10 psi i have the greddy turbo kit so i need to un install the black box and i just uninstalled the FMU and i'm still rich at idle so i guess next is the black box
any help is greatly appreciated
hybridb18
Apr 24, 2003 08:45 AM
D16SI
Feb 5, 2003 06:10 PM
chirp3rd
Feb 3, 2003 04:56 PM
MikeMAN
Feb 1, 2003 10:23 PM
00 Si
Jun 28, 2001 08:55 PM
