JE piston compression HELP needed
Old Mar 18, 2004 | 08:01 PM
dEtSoOb's Avatar
Default JE piston compression HELP needed
I'm looking into buying some 81mm JE 9:1 pistons, and I found some for sale for a good price, but the seller says that he bought them for a gsr motor whereas I am running a b16. I know that both stock bores are 81mm but what I am wondering is are the pistons going to be a different compression in my motor due to the fact that b18c's and b16a's have different compressions to begin with?
Old Mar 18, 2004 | 09:33 PM
dEtSoOb's Avatar
Default Re: JE piston compression HELP needed (HKesque)
bump
Old Mar 18, 2004 | 10:17 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
compression will be considerably lower than 9:1
Old Mar 18, 2004 | 11:57 PM
11psiTurboSI's Avatar
I have 9:1cr JE GS-R pistons too and they yeild a 8.8:1cr in my b16a2 with stock head gasket!
Old Mar 19, 2004 | 12:12 AM
Ben Huynh's Avatar
Default Re: JE piston compression HELP needed (9psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">I have 9:1cr JE GS-R pistons too and they yeild a 8.8:1cr in my b16a2 with stock head gasket!</TD></TR></TABLE>
That's about right Moe.
Old Mar 19, 2004 | 12:27 AM
Default Re: JE piston compression HELP needed (ben@importparts.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com &raquo;</TD></TR><TR><TD CLASS="quote">
That's about right Moe.</TD></TR></TABLE>
Which I purchased from you
Old Mar 19, 2004 | 10:02 AM
Ben Huynh's Avatar
Old Mar 19, 2004 | 12:05 PM
TurboTegB18c's Avatar
THey will drop compression Approximately 1 full point, which will make it 8:1. 8.8:1 compression will only factor in the compression loss from the head alone.
dc2_916
Sep 14, 2008 10:23 AM
B00ST2nR
Sep 22, 2004 02:50 PM
Sprockett
Feb 11, 2004 11:53 AM
cloproductions
Jul 9, 2003 08:21 PM
Killer_B
May 29, 2003 07:03 PM
