** The E85 Thread **
Old May 21, 2007 | 03:36 PM
  #101
96-EJ6 B18C's Avatar
Default Re: (Kelly.)
What are you guys paying per gallon for E85??? I just called the place that carries it in this area, they want $3.45/gallon 92 octane is going for $3.49/gallon
I was planning on converting my Civic, but with it being that expensive I may as well just keep running 92 octane.
Old May 21, 2007 | 03:39 PM
  #102
tony1's Avatar
Default Re: (96-EJ6 B18C)
$3.45/gallon is cheaper than 105octane race gas. If you're not making more power than you can safely make on pump gas, then there's no reason to change anyways.
Old May 21, 2007 | 03:52 PM
  #103
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">$3.45/gallon is cheaper than 105octane race gas.</TD></TR></TABLE>
Absolutely!
I just have a stock B16 so there is no "need" to switch to E85. However, I have seen some people's posts saying they're getting E85 for $2.70-$2.90. I figure if that was the case I may be able to save a few bucks by switching, and not giving the oil companies my $ is a plus in my book.
Old May 21, 2007 | 04:19 PM
  #104
tony1's Avatar
Well, regardless of the price, you'll use about 30% more of it, so you generally won't save anything by switching to it over 93.
Old May 21, 2007 | 04:26 PM
  #105
tony413's Avatar
Default Re: (tony1)
****WARNING IMMATURE POST**** im not offending on purpose only as a joke
i think hes tring to stop funding the terriorist since their families own the oil companies
Old May 21, 2007 | 07:14 PM
  #106
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Well, regardless of the price, you'll use about 30% more of it, so you generally won't save anything by switching to it over 93.</TD></TR></TABLE>
Is that what you have seen in your customer's vehicles? All the literature claims that you only lose like 10%-15% in fuel mileage. Just curious what those of you who are actually using it are seeing. Thanks for the input!
Old May 21, 2007 | 07:17 PM
  #107
tony1's Avatar
Well, i can tell you that you'll max out 1000cc injectors and a walbro pump around 450-475whp, where you'll max out the same setup closer to 650whp on gas. That's about 30%.
Old May 21, 2007 | 07:23 PM
  #108
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Well, i can tell you that you'll max out 1000cc injectors and a walbro pump around 450-475whp, where you'll max out the same setup closer to 650whp on gas. That's about 30%.
Word!
Old May 21, 2007 | 07:35 PM
  #109
nowtype's Avatar
Default Re: (tony1)
14/9.76=1.4344262295081967213114754098361
14.7/9.76=1.5061475409836065573770491803279
stoich vs stoich we are looking at about 1.5x more fuel. People generally tune E85 a bit leaner, but overall expect 1.3-1.5x more fuel consumption. The auto manufacturers and E85 nuts are liars.
Old Jul 16, 2007 | 04:14 PM
  #110
cJ_EG2's Avatar
Default Re:
What spark plugs are you guys running on your turbo E85 set-ups?
I've looked everywhere and i cant find anyone talking about certain spark plugs for E85.
Any help would be appreciated!!!
Old Jul 16, 2007 | 05:22 PM
  #111
tony1's Avatar
Default Re: (nowtype)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">14/9.76=1.4344262295081967213114754098361
stoich vs stoich we are looking at about 1.5x more fuel. People generally tune E85 a bit leaner, but overall expect 1.3-1.5x more fuel consumption. The auto manufacturers and E85 nuts are liars.</TD></TR></TABLE>
Maybe, but from my experience E85 does NOT like to be run leaner than 93 octane under power.
Old Jul 16, 2007 | 07:17 PM
  #112
batboyvaj's Avatar
what kind of mileage are all of you getting with e85? considering you drove nicely... how many miles to your tank?
Old Jul 16, 2007 | 09:22 PM
  #113
purpleh22's Avatar
Default Re: (batboyvaj)
I'm running E85 with the same plugs I ran using 113 octane race gas. I'm getting around 20 mpg but sure like getting fillups at stations vs. 55 gal drum routines.
(H22, 92 hatch, Gt30, 435 whp @ 17psi, 10:1, built eng.)
Old Jul 16, 2007 | 10:23 PM
  #114
racin jasin R's Avatar
Default Re: Re: (cJ_EG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cJ_EG2 &raquo;</TD></TR><TR><TD CLASS="quote">What spark plugs are you guys running on your turbo E85 set-ups?
Any help would be appreciated!!! </TD></TR></TABLE> we have E85 averywhere but what plugs are best bkre7???
Old Jul 17, 2007 | 07:28 AM
  #115
batboyvaj's Avatar
i'm trying to see how lean i can run my car while crusing to see if i can help the mpg
Old Jul 17, 2007 | 08:29 AM
  #116
SOHCD16y8's Avatar
We usually see around 22 city and 25 highway being pushed a bit everytime driven.
Old Sep 4, 2007 | 12:07 AM
  #117
Rosko's Avatar
Default Re: (SOHCD16y8)
Does a 30% increase in fuel hold true for the entire map?
Old Oct 8, 2007 | 07:46 AM
  #118
91civicDXdude's Avatar
Default Re: (Rosko)
http://www.epicinfo.org/?p=74
http://ethanolproducer.com/art...=2366
http://www.lifeline-foods.com/
Lifeline Foods is my employer. We recently opened a 40mmgy ethanol plant to compliment our corn milling operation. This is the future of ethanol production; we arent "stealing" corn from food, we're making ethanol after all the human consumption food value has been extracted from the corn kernel. We also burn wasted corn particles better known as bran in a boiler system called a gasifier to reduce the initial fossil fuel input to create said ethanol. New technologies can indeed prove very valuable to the sustainability of ethanol in the US. I'd be happy to talk more about it if anyone is interested.
Btw, E85 sells for about $2.25 a gallon here in saint joseph, missouri
Old Oct 8, 2007 | 01:02 PM
  #119
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (91civicDXdude)
from what i gathered is that although its about 30% more fuel at wot, its not nearly that much when cruising, becuase of the extra power (due to ignition timing) the car wont need to be pushed as hard to do the same amount of work at certain throttle angles
i wish we had this stuff in pa, i just did a research paper on it and would like to use it myself
Old Oct 8, 2007 | 02:37 PM
  #120
nowtype's Avatar
Default Re: (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">from what i gathered is that although its about 30% more fuel at wot, its not nearly that much when cruising, becuase of the extra power (due to ignition timing) the car wont need to be pushed as hard to do the same amount of work at certain throttle angles
i wish we had this stuff in pa, i just did a research paper on it and would like to use it myself</TD></TR></TABLE>
Wrong.
Old Feb 23, 2008 | 06:04 PM
  #121
BIG T's Avatar
Default Re: ** The E85 Thread ** (Kelly.)
planning on run E85 but wanting to know if it is possible to get tuned on E85 and GAS and then have a switch that would allow me to switch between the 2 type of fuel. So that i can run E85 but not run the risk of getting stranded when E85 isn;t around.
Old Feb 23, 2008 | 07:08 PM
  #122
Wrong.</TD></TR></TABLE>
tell me how this is wrong, unless you have first hand experience and can prove all the research i did wrong then you dont need to talk... ive researched this quite a bit and it seems what i stated to be true, although it may not be beneficial to the average consumer, it is to those people who want to push the timing on their boosted honda's and still be reliable
Old Feb 23, 2008 | 07:49 PM
  #123
nowtype's Avatar
Ignition advance is not going to make a lick of difference with E85 vs 87-93 octane when you are talking about part throttle. You aren't going to find too many cars that have part throttle detonation issues on 87-93 octane fuel so finding MBT is not an issue. You are going to gain a very small amount of power with E85 due to the cooler combustion, but again, not that much. So, yes, you can claim that with E85 you will need slightly less throttle because of the extra power. To offset this, gasoline is a better fuel to lean burn with vs E85 as it doesn't care to lean burn at all, so that difference in power will be offset by the fact I can run my gasoline engine leaner without significant power loss. So really, the 30% is more than fair to apply. If you want to argue it's 28% vs 30%, I'm not going to bitch. But if you think the difference will become 10% like GM claims, well then, I'd ask you to prove it because those same GM cars that claim only a 10% difference in actually have the standard 30% difference.
Old Mar 11, 2008 | 10:01 PM
  #124
98lude-t's Avatar
lovin this thread even tho its a few years old. ill post my #s soon.
Old Mar 12, 2008 | 08:14 AM
  #125
servion's Avatar
Default Re: ** The E85 Thread ** (BIG T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIG T &raquo;</TD></TR><TR><TD CLASS="quote">planning on run E85 but wanting to know if it is possible to get tuned on E85 and GAS and then have a switch that would allow me to switch between the 2 type of fuel. So that i can run E85 but not run the risk of getting stranded when E85 isn;t around.</TD></TR></TABLE>
I tune setups for both fuels all the time
