How do you get rid of the check engine?
Old 08-19-2013, 12:28 PM
Soup Slayer's Avatar
Default How do you get rid of the check engine?
Greetings ya,ll... I hope all is well.
I'm quiet new to the honda realm, and i've recently purchased a 1998 honda civic from some random off craigslist. It's an automatic with 165k so of course it has had some problems. Recently took it to get smogged and it FAILED! due to
P0325 Knock Sensor 1 CKT malfunction and
P0135 O2 Sensor hearter fault (Bank 1 sensor 1)
I asked around and they said the car wouldn't run if the knock sensor was not working (the car runs perfect)...
Also i recently replaced the o2 sensor myself.
I was wondering how I can clear the Code
My friend tried to use an OBD2 scanner but There was an error code which I can post if that would help...
Sorry this has became lengthy, i'm just trying to pass this smog!!!!..
Old 08-20-2013, 07:36 AM
Default Re: How do you get rid of the check engine?
194 views and nobody has an answer? INSANE!...
THE OBD2 Scanner had a communication error with my ECU.
I've tried leaving the negative unplugged for a length of time aswell.
I have a couple more days to get this smogged! Suggestions would be awesome!
Old 08-20-2013, 09:06 AM
motoxxxman's Avatar
I'd say check the basics: all fuses, wiring damage, and clean all the ground connections in the engine bay, as well as cleaning the battery terminals and making sure they're tight
Old 08-25-2013, 08:55 AM
efinimazda's Avatar
or u could remove the CEL bulb
Old 08-26-2013, 02:19 AM
motoxxxman's Avatar
seriously? are you that dumb that you would suggest that? the OP failed emissions, he needs to fix whatever the issue is so he can pass emissions. the cel is there for a reason, because there's a problem. how does removing the bulb solve anything.
Old 09-02-2013, 08:20 AM
efinimazda's Avatar
Hah! I'm glad you appreciate my response... once the bulb is gone the problem goes away, DUH!
Old 10-16-2013, 08:28 PM
fishbol's Avatar
^This +10,000
DCWOOD
Honda Civic (2001 - 2005)
11-07-2013 11:48 AM
Soup Slayer
08-20-2013 08:15 AM
crx2hatch
02-10-2011 06:30 AM
EG6[B16A1]
10-19-2003 11:22 AM
Unsung
05-06-2002 06:28 PM
Quick Reply: How do you get rid of the check engine?
