Secondary 02 Sensor on OBD-2
Old May 6, 2002 | 06:02 PM
Unsung's Avatar
Default Secondary 02 Sensor on OBD-2
Hey, Just build a test-pipe for my 00 Si and my o2 sensor doesn't have a home anymore. Just curious what I can do about this so my check engine light won't be on. Thanks.
Old May 6, 2002 | 06:07 PM
MrFatBooty's Avatar
Default Re: Secondary 02 Sensor on OBD-2 (JDM B Series)
You can get an O2 sensor simulator from importparts.com for 40 bucks. It's made by ECG Electronics. Go to the "Electronics" section of their site and you should find it.
Old May 6, 2002 | 06:10 PM
Unsung's Avatar
Default Re: Secondary 02 Sensor on OBD-2 (MrFatBooty)
I heard something about grounding out the second 02 sensor, know anything about that?
Old May 6, 2002 | 06:12 PM
MrFatBooty's Avatar
There's some kind of wiring trick you can do (it may be grounding out the sensor) that will fool the ECU most of the time. The thing is that the signal is supposed to vary a lot and after a while the ECU will throw a CEL if it sees the same signal constantly.
Old May 6, 2002 | 06:28 PM
Unsung's Avatar
Yeah, it trips code when I stay a constant speed when the car warms up. I'll look into the thing at importparts.com.
Anyone know about the ground-out trick?
DCWOOD
Honda Civic (2001 - 2005)
Nov 7, 2013 11:48 AM
vtec2nv
Apr 12, 2013 04:52 AM
hondaaccord94
Mar 26, 2005 07:40 PM
Lewie
Jun 29, 2004 09:11 AM
