when to change a o2 senor
Old Oct 18, 2003 | 11:08 PM
EG6[B16A1]'s Avatar
Default when to change a o2 senor
hey...
I like to know, what are the side effects that show that you have a bad o2 sensor???
or any sensor?
also a knock sensor too.
please post up what you know, that may be valuable info to everyone.
I've did a search...have'nt found my answers...maybe this would work
thanks so much
Old Oct 19, 2003 | 11:22 AM
sleepyEK's Avatar
Default Re: when to change a o2 senor (EG6[B16A1])
well first of all it depends on what year you are talking about. on the non obds you can tell because the car runs really rich. the knock sensor can sometimes be bad and not throw a code on non obd motors. the best way to test the knock sensor is with a graphing multi meter. hook it up and see if it is sending a constant voltage which it shouldn't be. the knock sensor only throws a code if there is an open in the circuit.
m3bluegsr
Sep 3, 2004 07:59 AM
davken1102
Feb 6, 2004 10:42 AM
SuperMan19
Oct 20, 2002 10:05 AM
1.8EG-T
Nov 5, 2001 12:08 PM
