P2W and ring gap.
Old Sep 4, 2013 | 04:56 AM
  #26
MR.johnson's Avatar
Default Re: P2W and ring gap.
Originally Posted by Flr Power
Yes, I run .012'' P2W with my 4'' downpipe and all is good.lol
On E85 0.020 top ring is safe and I would go 0.025 middle ring.
Come on. I was only joking about the fact that some guys run very loose clearances.
I personally run .003 PTW with CP pistons and I run 0.018 top and 0.023 middle.
I also use water/meth.
wtf?
Old Sep 4, 2013 | 06:10 AM
  #27
4piston's Avatar
I have found some brands of pistons need to have more wall clearance because they expand a lot more with heat than other brands even of the same material. It also depends on the design of the piston, where the breakover point it, what kind of taper is in it, etc.
Old Sep 4, 2013 | 10:45 AM
  #28
MR.johnson's Avatar
so heres what we came up with...
p2w: (.040) .045 max
top:.017
middle:.019
look ok for 800-1000hp on E?
Old Sep 4, 2013 | 10:55 AM
  #29
luck4rmkc's Avatar
Originally Posted by SPOOLINmatt
You can run .009-.011 with an up pipe and feel good about it. LOL.
If i cant hear it, maybe its not so much of a problem.
I'm assuming one or both of these posts were trolling... If in response to my comment about not being able to hear it over the regular noises of the car then thanks for that.
I wasn't saying if you can't hear it then oh well but my clearances were intentionally selected for gasoline (not ethanol) for intended current and future power levels. I was intending to simply point out that a little loose is better than a little tight. I can tell you with .0065" I can't even hear any slap with a stethoscope cold in my Honda. My 120k Chevy 5.3L clacks like hell every morning and it is perfectly reliable.
If it helps the OP any I ran .0035" P2W on my last motor with 18 top ring gap at 600whp without problems on E85. Adding another 200 whp I would think another 2 thou on top of that would be smart. That is just my opinion though.
Old Sep 4, 2013 | 04:59 PM
  #30
13173's Avatar
top:.017
middle:.019
I do not have my build sheet sitting next to me, but I think that is something along the lines of the clearances I used for my build. Not looking to make as much power as you, but that was what was suggest for me.
Old Sep 4, 2013 | 05:09 PM
  #31
Flr Power's Avatar
top:.017
middle:.019
CP recommends going .004” - .008” bigger than top ring.
Old Sep 5, 2013 | 05:57 AM
  #32
poorboy44's Avatar
Yea, the rings cp sent me were huge... When I called them to ask about it, they told me the same thing.... We'll see how it goes once I fire my motor up
Old Sep 5, 2013 | 10:50 AM
  #33
gringotegra's Avatar
top:.017
middle:.019
We shoot for those ring gaps on all our motors.
As far as PTW, maybe shoot on the looser side of things just incase. 5-5.5.
Old Sep 5, 2013 | 04:28 PM
  #34
13173's Avatar
I had some rings for my pistons that CP sent. In my cylinder bores before I even did any ring filing some of the measured at around .029". They had really big gaps, I had to order a new set with a different part # so I could actually gap them to where I wanted them.
Old Sep 9, 2013 | 01:01 PM
  #35
4cylfiend's Avatar
I built my engine knowing that I was only going to be running E85. I run a custom JE piston as well.
My p2w is 0.005
Top ring- 0.020
Bottom ring- 0.024
I was only running 28psi with my 6266 and the engine made 738/530. Didn't have hardly any oil in the catch can after consecutive pulls on the dyno
Apr 15, 2013 07:37 AM
SSBPGSR
Mar 28, 2005 12:52 PM
lsvtecvx
Mar 19, 2003 03:16 AM
TheSwift1
Oct 22, 2002 02:59 PM
quikrpm'z
Oct 5, 2001 08:05 AM
