K series forced induction CP Piston clearance?
Old 04-14-2013, 09:32 PM
13173's Avatar
Default K series forced induction CP Piston clearance?
I picked up a set of used 87.5mm CP Pistons for a K24 stock sleeve setup. I talked with one experienced builder and he said to run what CP calls for, which is a .0035" P2W clearance. I have researched a little and found that some people do not like that and think it is a little to tight and they run theirs at .0040-.0045" with good results. That was with B series engines though.
Anyone in here have experience putting together a K24 with these pistons? If so please give me your opinion and what you like to use for P2W and what you like to use in the ring gap dept too.
The engine will be more of a street engine and will be run on gasoline. Ethanol is not available near me. I will be using a PTE 6765 and it may get a race gas tune in the future.
Old 04-15-2013, 06:07 AM
kyden's Avatar
Default Re: K series forced induction CP Piston clearance?
I think it is too tight.
Old 04-15-2013, 07:35 AM
Moderator in Chief
Muckman's Avatar
Agreed, its too tight for that bore, power and fuel.
Old 04-15-2013, 07:37 AM
13173's Avatar
.0035" seems to be too tight according to the two guys that have posted. Who has experience with the K series engine and what sort of clearance should be ran for my setup?
Gtimiike
05-08-2018 07:25 PM
zombie247
10-22-2015 01:37 PM
froggy123
11-11-2012 04:48 PM
JDMEMone
16
02-13-2012 05:46 PM
christoble
07-28-2005 05:47 AM
Quick Reply: K series forced induction CP Piston clearance?
