EPERIENCED engine builders...what clearances are u guys running??
Old Oct 22, 2002 | 04:39 AM
TheSwift1's Avatar
Default EXPERIENCED engine builders...what clearances are u guys running??
JE 9:1 comp. pistons with stock sleeves, stock bore B18C...what piston-to-wall clearances are u guys running for 300-400WHP applications? JE recommends .0040, but I wanted to know if i should go slightly looser or what...thnx guys...
[Modified by TheSwift1, 2:46 PM 10/22/2002]
Old Oct 22, 2002 | 07:43 AM
earl's Avatar
Default Re: EXPERIENCED engine builders...what clearances are u guys running?? (TheSwift1)
Do exactly what JE recommends for your application. Too loose and you will be burning oil in 1000 miles..too tight and you will soon lose compression with piston black death.
Old Oct 22, 2002 | 10:18 AM
TheSwift1's Avatar
Default Re: EXPERIENCED engine builders...what clearances are u guys running?? (earl)
Old Oct 22, 2002 | 10:20 AM
b18bturbo's Avatar
always follow the piston specs given to you.
Old Oct 22, 2002 | 11:08 AM
The_Head's Avatar
...too tight and you will soon lose compression with piston black death.
Could you explain what this is?
Old Oct 22, 2002 | 11:19 AM
blkDOHCsol's Avatar
New User
Default Re: EXPERIENCED engine builders...what clearances are u guys running?? (xThexHeadx)
how do you control your piston to wall clearance??
Old Oct 22, 2002 | 11:21 AM
b18bturbo's Avatar
Default Re: EXPERIENCED engine builders...what clearances are u guys running?? (blkDOHCsol)
the way you control is based on your bore of the motor. you usually need ot bore the motor to the spec of the piston. Some builders do it the opposite whihc in my opinion is ***.. You should never bore just a plain block with out having the piston with you.
That is way you can keep your piston to wall clearance in spec. Alwlays do the correct hone job with a good stone also helps the rings seat faster thereby no blowby
Old Oct 22, 2002 | 02:59 PM
earl's Avatar
Basically if there is not enough room for the piston to expand because of heat, the piston skirt will expand against the cyl wall. Too much heat is built up and soon the aluminum will blacken and distort. Once out of shape, you will loose sealing (compression) and it will begin to suck oil.
MR.johnson
Sep 9, 2013 01:01 PM
ValleySyder
Mar 8, 2006 09:54 AM
B18C_EJ8
Aug 24, 2003 05:19 PM
BLKCRX
Jul 24, 2002 03:40 AM
