Omg is this bad
Old Nov 24, 2007 | 02:15 PM
turboteg90's Avatar
pm for noodz
Default Omg is this bad
is it nessesary to run a dumptube ?
because i dont have one and there is no exaust leak
Old Nov 24, 2007 | 02:19 PM
Autoworks's Avatar
Default Re: Omg is this bad (turboteg90)
A dumptube is definately recommended.
Not having a dumptube will not cause an exhaust leak...seeing as how it is not connected to the exhaust (unless your running closed dump, which you obviously are not)
Old Nov 24, 2007 | 02:28 PM
Bseriescivic5's Avatar
dumptube is not needed. However it is always good to re-rout the hot exoust gases away from the compressor inlet and keep underhood temps down.
Old Nov 24, 2007 | 02:29 PM
turboteg90's Avatar
pm for noodz
Default Re: Omg is this bad (Autoworks)
im running a tial 38mm waste gate and i bearly noticed that it had another plug for the dump tube .i bought the car with a ssac manifold so i was looking at new manifolds when i encounter this
Old Nov 24, 2007 | 02:41 PM
SpoolnG2's Avatar
all the dumptube does is reroute the exhaust gases that come out of the wastegate. If you dont reroute them, most likely your entire engine bay will turn black and whatever is in front of the wastegate port will melt or heat up a lot depending on what it is. Get a dumptube.
Old Nov 24, 2007 | 02:59 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Omg is this bad (SpoolnG2)
not to mention you will re burn exhaust gas, effectively making you non dump tube setup an EGR, this lowers cyl temps by introducing burnt exh into the charge, thus lowering power.
Old Nov 24, 2007 | 03:47 PM
RCautoworks's Avatar
You don't need one, but you should have one.
Old Nov 24, 2007 | 07:19 PM
turboteg90's Avatar
pm for noodz
Default Re: Omg is this bad (RCautoworks)
anybody got one for a tial 38mm
Old Nov 24, 2007 | 09:34 PM
lambertincorp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">all the dumptube does is reroute the exhaust gases that come out of the wastegate. If you dont reroute them, most likely your entire engine bay will turn black and whatever is in front of the wastegate port will melt or heat up a lot depending on what it is. Get a dumptube. </TD></TR></TABLE>
yea my bolts backed out of mine and it fell off haha looked like a chimney in my bay
Old Nov 24, 2007 | 09:46 PM
Dunc's Avatar
BCICAN
Default Re: Omg is this bad (lambertincorp)
How are some of you guys honestly telling this dude that he doesn't need a dumptube? Yea you don't "need" a downpipe either, but I 100% of everyone is using one. It's called the intelligent thing to do.
To the original poster: do not half *** something like this. Get a simple pipe made to fit your wastegate and route the exhaust gases away from vital parts of the engine.
Old Nov 24, 2007 | 09:50 PM
Default Re: Omg is this bad (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">How are some of you guys honestly telling this dude that he doesn't need a dumptube? Yea you don't "need" a downpipe either, but I 100% of everyone is using one. It's called the intelligent thing to do.
To the original poster: do not half *** something like this. Get a simple pipe made to fit your wastegate and route the exhaust gases away from vital parts of the engine. </TD></TR></TABLE>
A downpipe would melt stuff, regardless. I mean, I would never ever run a car with out a dump, but you really don't need one.
You don't need oil either, but you should run it.
Old Nov 25, 2007 | 02:35 PM
The simple answer is that the car will operate ok without one. But it is a good investment and will keep things clean and running better.
Old Nov 25, 2007 | 02:52 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">A downpipe would melt stuff, regardless.</TD></TR></TABLE>
Being the devil's advocate: no dumptube will melt things just like no downpipe would. All it would take is a long 1-5 gear pull with the wastegate pointed in the right direction.
Old Nov 25, 2007 | 04:05 PM
I ment no downpipe
Old Nov 25, 2007 | 04:24 PM
HiProfile's Avatar
Forced induction is the art of stuffing as much OXYGEN into the motor, using no gaseous substance other than atmosphere.
Running no dump will release 'dead' air into your engine bay, <U>air w/o any oxygen left</U>. It may have 1% of it left, but you still have way more soot and unburnt gasoline. That dead air will take up space in your cylinder, make you run a bit rich, and also increase IAT's. NONE of those help make power when you run them on a good tune.
Old Nov 25, 2007 | 04:43 PM
.PLUMMM's Avatar
not needed but recomended keep that engine bay temp down and away from your compressor housing!
Cloneufc
May 13, 2009 05:57 PM
jorge59la
Mar 24, 2007 05:49 AM
dezerte
Mar 8, 2007 06:57 AM
Built B16A
Feb 18, 2004 12:02 PM
Integra808
Apr 3, 2003 06:08 PM
