-March FS Thread-
Old Mar 24, 2012 | 04:50 PM
  #76
Sickteg24's Avatar
Default Re: -March FS Thread-
I have 4 Precision 1000cc low impedance injectors for sale. Just received them back from Livernois where they were flowed. Already have new injectors just looking to get rid of them. Price $250
Old Mar 24, 2012 | 07:31 PM
  #77
FRernesto's Avatar
A few items for sale all are in good working condition if not new. Prices negotiable.....
-MF2 Mappable Injector Driver can control either additional fuel injectors or water injection and 2bar map sensor. Instructions included (USED) Make an offer...
-TiAL new 60mm inlet flange. (NEW)25.00
-Injector resistor box plus OBD1 injector clips. (USED)45.00
-35mm Exhaust flange plus gasket. (NEW)15.00
-AEM UEGO does not come with sensor as its recommended to use a new one. One can be included that still works for 130.00 without 100.00. SOLD!
-Borg Warner turbin housing Twin scroll 1.10ar for S400SX 71mm turbo. 125.00 New never used!
Old Mar 24, 2012 | 07:52 PM
  #78
boostontheD's Avatar
i have a complete FMIC for sale
go-autoworks 600whp backdoor intercooler with BOV flange on side.
2 1/2 in piping for 5th gen coupe. may fit others. was in my coupe with GE intake manifold and 70mm TB
comes with all clamps and couplers
the TB couple and 2 clamps are not pictured but will come with it.
has ebay tyle style BOV. worked just fine for my setup that made 475whp. its just quite.
only reason im selling it it because it will not support the power i wanna make with the next setup.
everything is in great shape.
price is
500shipped plus PP fees
Old Mar 25, 2012 | 05:14 AM
  #79
94snatchback's Avatar
sold
Old Mar 25, 2012 | 05:59 PM
  #80
sohc95vtec-t's Avatar
Went a little different direction with my build, so I have a few things laying around I dont need. Paypal either as a gift, or add 3%. Plenty of vouches if needed
- 15x10 with 6" back space Weld Magnums. Virtually brand new, barrels were freshly polished inside and out professionally by CCW, and the centers are brand new replacements from Weld. Never ran since redoing them. SOLD..
- Brand new OEM drivers/passenger mirror block off plates for EG (driver side was opened, but still new) $75 shipped
- 70mm skunk2 throttle body (brand new, only opened to look at) $225 shipped
- Brand new MSD distributor cap and rotor kit for GSR (to accept an external coil) $40 shipped
Custom dual backdoor intercooler. In used, but in good working condition. Has a few dents and dings, but is in perfect working order. Overall dimensions are 35"x13"x3.5" (core is 24"). 3" inlets/outlets $400 shipped
Old Mar 26, 2012 | 08:40 AM
  #81
boosted hybrid's Avatar
FCS 5 gallon fuel tank with fuel sender unit. Used for a few races, in excellent condition. Has built in fuel level sender, and (2) -10 a.n feed from sump on tank. The tank was modified with -10 a.n drain on sump tray for draining, and added -8 a.n for return. Aluminum holding straps were also welded to tank for more sturdy mounting. Sold!
4" Custom Stainless Up-Pipe for Full Race TS T4 top mount Custom fabricated 4" stainless steel v-band up pipe that was paired to a Full Race T4 twin scroll manifold using a s400sx/42r style turbo. Has (3) o2 bungs welded onto the pipe. Sold!
CNC staging brake with rear lines/fittings for civic/integra disc brakes. Used for 2 races, in excellent condition. The CNC staging brake was modified to be a drop in fitment into a civic/integra where the OEM hand brake goes. A baseplate was fabricated that bolts to the OEM bolt holes where the OEM hand brake was located for fastening. A momentary contact switch was also fabricated onto the hand brake for triggering 2 step, or other devices. Comes with custom -3 a.n rear lines to rear calipers and -3 a.n adapter fittings to brake caliper. This is a drop in "kit" that converts the rear brakes to be independently controlled hydraulically by the staging brake only. $300.00 shipped in the 48 states. Sold!
Brian Crower Stage 3 N/A camshafts and Skunk2 Tuner Cam Gears. Brand new BC stage 3 N/A camshafts, work great for big power turbo set-ups. Same cam as the "NRG TECH SFWD Cam". Including skunk2 tuner series cam gears. Sold!
Bosch High Impedance 1600cc/min injectors. 2 brand new sets of Bosch high impedance 1600cc/min injectors. Great for E85 applications. One set is machined for 11mm (b/d/h/s2000) and other set is standard 14mm (k series). $375.00 shipped each set in the 48 states.
T1 catch can w/ -10 a.n bungs, fittings/lines and valve coverT1 catchcan with -10 a.n bungs, black braided lines/fittings and black power coated OEM valve cover. Used, in good condition. Valve cover comes with (4) -10 a.n fittings already welded. Complete "kit" ready to install. Includes -10 a.n steel block freeze plug adapters. $550.00 shipped in the 48 states.
Tial 35/38/44/60mm wastegate springs Various colors in both "small" and "big" springs. $15.00 shipped in the 48 states for each.
AEM 4 channel thermocouple amplifier. Used for mock-up only, in brand new condition. $200.00 shipped in the 48 states.
AEM 0-2000 psi pressure transducer (stainless) and 0-30 psi (2 bar brass) pressure sensors Both brand new in the box. $95.00 shipped on the stainless sensor and $35.00 shipped on the brass sensor.
Hurst line lock. Used for one race, in brand new condition. $75.00 shipped in the 48 states.
LS2 "truck" coils w/mounting brackets, clips and pins Brand new LS2 truck coils, these are good for 150-200 hp per cylinder. Have built in ignitor, work great with AEM EMS or new hondata CPR unit. $100.00 shipped per set of 4. Have 8 "sets" available.
Forced Peformance billet inline -4 a.n oil feed filter Brand new FP billet inline oil feed filter, great for saving a turbo for metal shaving or debris. $70.00 shipped in the 48 states.
Comp stage 2 s2000 clutch kit Brand new Comp stage 2 clutch kit. Sold!
Co2 filling station Co2 main tank, transfer hose, (2) 5 lb bottles, 0-100 psi and 0-90 psi fixed regulators, billet 5 lb roll cage bottle bracket and inline auto shut off valve. Used for testing purposes, in like new condition. Big tank allows transfer to smaller 5 lb bottles with supplied transfer tube, nice and simple filling station to anyone looking to run co2 for shifter, boost control, intercooler sprayer, etc. $500.00 pick up only.
All prices are fair and firm. Shipping is included in 48 states. Paypal is preferred payment. Pm or email tech@evans-tuning.com.
Old Mar 26, 2012 | 02:48 PM
  #82
Casey's Avatar
walbro 400lph in tank pump $125 shipped, 500 street miles on it
aem 3.5 bar stainless with pigtail, $55 shipped
prosport peak/warning boost and oil temp gauge, both light up white and or green
$100 shipped for the pair
Old Mar 26, 2012 | 05:47 PM
  #83
jamaljbenoit's Avatar
Contact Info:
Jamal Benoit
377-519-6599
Selling a K-series sidewinder T3 manifold with 44mm flange, 3" V-band down pipe, and dumptube. All were made by Peakboost and are brand new. They also have the HPC coating on them. Asking 1100 for all.
Old Mar 26, 2012 | 11:56 PM
  #84
mr2slo4u's Avatar
Back up for sale
97 EK with NHRA Certified 8.50 Chromoly cage
http://hondamarketplace.com/showthread.php?t=3041190
Old Mar 27, 2012 | 01:56 PM
  #85
TimKennard's Avatar
prices are shipped to anywhere in the lower 48 states. i'm in washington so we can work a deal if no shipping. don't like my prices? make an offer, worst thing is i say no.
Supertech P4-H845-P1 1.4cc dome, 11.5:1 piston set. bnib opened for pics. comes with rings, wrist pins, and locks. $400 obo
cometic 84.5mm head gasket for b18/b20 w/vtec head bnib, $80 shipped
mac valve ebc solenoid with pushlock fittings and some blue tubing, $60 shipped
greddy gsr timing belt, SOLD
rdx injectors SOLD
omni 4 bar map sensor, SOLD.
Old Mar 27, 2012 | 08:08 PM
  #86
SFWD 1934's Avatar
I have a few parts for sale. Prices are plus shipping to the lower 48. Paypal and square payments are available.
1 set of brand new never used B series black AEM cam gears
$100 for the pair
1 brand new never used B series silver AEM fuel rail
$75
1 set of JGE (JG Racing Engines) B series turbo cams
$200 for the pair
1 set of four RC Injectors 1000cc injectors
$200 for the set
1 1995 Acura DC2
Clean title
JDM front engine
Complete car was resprayed milano red
JDM cluster/rear seats/door panels/center rest delete/climate control
New rear quarter windows
New front windshield
New gutter moldings
Seibon carbon fiber front lip
Seibon carbon fiber hood
Seibon carbon fiber hatch
Vision carbon fiber mirrors
Skunk2 front upper control arms
BLOX Competition coilovers
BLOX rear lower control arms
BLOX solid rear spherical trailing arm bushings
All new HONDA hardware for suspension/motor/car
Earls stainless steel brake lines
Power Stop slotted rotors front/rear
Hawk pads
Built B18C1 84MM
CP Pistons
Scat rods
Built B18C1 head
Stock GSR cams
Edelbrock intake manifold
Ericks 70MM throttle body
2.75" 1 piece charge pipe
Custom black anodized intercooler 24x12x3.5
Full-Race twin scroll top mount
Garrett GT4294R
Tial silver 44s
Tial silver BOV
ARP 12pt stainless steel hardware all over the engine/engine bay
AEM fuel rail/filter/fpr
ID1000 injectors
HONDATA S300
AEM boost/AFR gauges in the dual gauge pod around the cluster
NRG front seats (Type R replica)
450 miles on car/motor since the build. I am certain that I forgot stuff off of this list, but it gives you an idea of the car. Any questions call or email me. Number is in the sig.
I could not upload the pics? What the hell.
Jason
Old Mar 28, 2012 | 09:14 AM
  #87
JDM346's Avatar
Default Dart sleeved 2.5 Brian Crower stroker f20c engine
Selling my stroker engine bc I'm swapping in a K24 into my s2000...7600 miles on the motor...no issues at all...comes with all paper work/receipts and boxes from parts...fast motor setup...Shoot me a call or text at ***336 575 0563*** for more info or pics/vids......$4000 OBO priced to sell quick
Forged Engine:
Brian Crower Stage 2 cams ($650)
Brian Crower Dual spring, steel retainer/seat ($360)
Crower Crank - March '11 ($1850.00 + $200.00 for balancing)
Crower Rods - March '11 ($670.00)
89mm CP Pistons - March '11 ($550.00)
Darton Sleeves - March '11 ($656.00 + $600.00 for installation)
ARP Headstuds - March '11 ($160.00)
Race Series Preformace Engine Bearings - March '11 ($180.80)
Cometic .05mm Head gasket - March '11 ($94.90)
AEM v2 Intake - August '10 ($300)
AEM 1052u EMS - March '11 ($1500)
RLZ Tune on 1052u - March '11 ($500)
OEM Valve Retainers - March '11 ($90.00)
Invidia 70mm Test Pipe ($90.00)
Invidia N1 titanium tip full exhaust ($900)
Stage 2 ACT Street Clutch - July '11
ACT Heavy Duty Pressure Plate - July '11
($596.00)
New Timing Chain ($100.00) From Honda
New Timing Chain Tensioner ($149.00) From Honda
New Oil Pump Chain ($49.00) From Honda
New Alternator at the start of fall (Early October)
Black valve cover
Standard 11:1 compression so that it could still run on 93 octane pump gas.
With your purchase you are receiving over $7,500 in parts alone.
Long Block:
Block
Pistons
Rods
Crank
Oil pump
Timing assembly
Head
Cams
Rollers
Etc
All Accessories:
Intake manifold
Fuel rails/injector
Starter
Alternator
Water pump
A/C Compressor
Pulley's
Header
Engine Mounts
Etc...
Wiring Harness:
Full Wiring Harness with all sensors and plugs.
the pics are on this post:
http://www.hondamarketplace.com/show...highlight=dart
Old Mar 28, 2012 | 03:14 PM
  #88
blacK_Dc4's Avatar
rocket motorsports m25xx cams with spoon cam gears. Cams have about 2000 miles on them. SOLD!!!!
Old Mar 28, 2012 | 06:51 PM
  #89
Universal Magnetic's Avatar
Located in PORTLAND OR
EMAIL: jsanjuan360@hotmail.com
PAYPAL VERIFIED...BUYER RESPONSIBLE FOR PP FEES
Ford Motorsport 1600cc injectors SOLD
AEM 2710 10 channel Peak and Hold driver box $150 shipped
-used in combination with 1600's and worked great!
Old Mar 29, 2012 | 11:16 AM
  #90
known's Avatar
GSR B18C crank scraper that will work with an LS B18A/B. Potentially add 1-2% hp gains from testing done years ago.
If you want to run this on an LS B18:
It will work but the teflon may need to be trimmed.
Kevin said if you want the windage tray for the LS while using this scraper it would need to be sent in while the LS tray was modified together with the scraper.
I believe this could be an older model, I purchased it used.
$160 shipped
Old Mar 29, 2012 | 12:55 PM
  #91
FaceTuned's Avatar
contact:
Tony
253-224-1792
Tony@facetuned.com
www.facetuned.com
buyer pays shipping/ pay pal fees.
Turbonetics T3/To4e 57trim - $500 obo
Brand new no miles what so ever its a standard T3/5bolt outlet turbo
.60 cold side / .63 hot side good for 400-500 whp
FTT Racing Traction bar
Fits all
92-00 civic
94-01 integra
Condition Brand new comes with aluminum 5/8 radius rods for easy adjustment
clears big down pipes and fits with full size radiator
$250 - shipped
Old Mar 29, 2012 | 07:16 PM
  #92
extralargenog's Avatar
Competition Twin disk for H/F series.
Just freshened up a few hundred miles ago.
NEW updated disks (THE LATEST ones)
Replaced floater
Flywheel surfaced (And step corrected).
Good to go, Works flawlessly.
Going triple. Custom setup.
I ran this clutch on the street 99.5 percent of the time. No issues
800.
Old Mar 29, 2012 | 07:51 PM
  #93
Smokalicious's Avatar
OG Iceman eg headlight scoop $100
BC stage 3 B16/B18C All Motor/ Turbo Cams $350
Blox 3" Velocity stack kit in black, stack used filter new $60
AutoMeter 5343 Digital Shift light Barely used $140
Rage Big Tube Header $500
Also have a set of SuperCams for sale i paid 800 from Humble Performance taking offers
text 316-299-9469
items are O.B.O shoot me a offer
Old Mar 30, 2012 | 01:47 PM
  #94
BlueByYou's Avatar
used id2000 injectors b-series $700 without clips
Old Mar 30, 2012 | 02:05 PM
  #95
RHDHOTSAUCE's Avatar
wts B- series Hytech Turbo manifold W/ Tial 46 mm wastegate $1550 shipped in paypal already included 206-335-9207 MY ONLY reason for saling this SUpER RARE manifold is because my K swap is done.... idk y i cant upload pics so text me for pics.. thanks
Old Mar 31, 2012 | 06:30 AM
  #96
SL0WEGG's Avatar
$1750 obo
Used for one season, going a different route.
Full blown motorsports h22 t4/split housing/dual wg(46mm precision flanges
BEP S372
Alternator relocation bracket
more pics here
http://www.flickr.com/photos/slowfot...7629717481019/
Wastegates not included.
h/f comp twin disc. Used for 2 seasons $700
crazes
Apr 19, 2018 07:51 PM
crazes
Mar 27, 2017 09:44 AM
crazes
Nov 18, 2016 05:52 AM
crazes
Oct 30, 2016 03:57 PM
crazes
Sep 5, 2016 02:16 PM
