Oct FS Thread
Old Oct 4, 2016 | 07:52 AM
crazes's Avatar
Moderator
Default Oct FS Thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
Old Oct 6, 2016 | 02:18 PM
jdm inc's Avatar
Default Re: Oct FS Thread
Sheepey ic $800 shipped
Borg Warner turbo 950 Obo
Dave fry wing $200 shipped
7l golden eagle intake manifold with Wilson 90mm tb and fuel rail $850 shipped will separate
Koyo rad with 13" spal fan and fan shroud $340 shipped
Super tech valves 1mm os missing two exhaust valves $160 shipped
Super tech valve guides $75 shipped
Pm for more info, prices are negotiable
fastest response text me at 316-308- four three six nine
Old Oct 7, 2016 | 02:59 PM
98B18C1's Avatar
FS: Bogart Fly Lites 13x8 front with M/T 24.5x9x13 slicks and 15x3.5 rear skinnies with M&H 24x3.6x15 tires
Still alot of meat on all tires - 1200 OBO will include spacers and lug shanks as well. Can ship at buyers expense
Old Oct 11, 2016 | 04:42 AM
EF'n Sedan's Avatar
Sold!
Old Oct 11, 2016 | 10:54 AM
ninesecrx's Avatar
Icon2 Re: Oct FS Thread
I am selling this complete running 1988 Honda crx drag race car. It has lots of mods, fully built engine and a bunch of high end parts. Car will need to be tuned before raced. Engine was built to run on nitrous or turbo. Should still run hard if ran all motor if you like. Car ran 10.80s ET in the 1/4 mile
12 point cage
tin work
Autometer tach and gauges
Painless switch panel
cnc stage brake
simpson cam lock 5 point harness and window net
full lexan windows with fast release dzuz fasteners
straight rear single axle with torsion bar
Mugen body kit shaved in with great condition paint
Jazz race seat
MB fiberglass 1 piece front end
comes with a set of front racing slicks
1 gallon Jazz fuel cell
breather box
msd 6al ignition with blaster 2 coil
scatter shield for transmission
race clutch with aluminum flywheel
steel braided lines all over
B series motor mounts for swap
energy suspension bushings through out
bosch fuel pump
tokico 5 way struts
DC header
Skunk2 intake manifold
aem intake
magnacor spark plug wires
Neuspeed front strut tower bar
BDL throttle body
SX fuel filter and fuel pressure regulator
vortech fuel rail and fuel injectors
obd1 wiring
RC cam gears
Head has been port and polished, Crower cams, Crower dual springs and retainers, ARP head studs
Bottom end has Crower rods, JE pistons, Benson sleeved block
Old Oct 11, 2016 | 01:43 PM
ninesecrx's Avatar
Selling a project that was almost finished. Here are some key points with tons of extra nice stuff done not listed. All parts are new. The car is fitted with a Honda s2000 engine and a GM racing 4t65e transmission
$15.000
1 piece fiberglass front end
25.5 spec cage with legal back half
strange spindle mount rear suspension
full tin work front and rear with custom tin dash
weld wheels front and back. Has some roll around front wheels as well. 5 lug
Garrett GT42R turbo , Tial wastegate
Accufab 90mm throttle body
Custom radiator and water to air pwr intercooler
Peterson dry sump pump, oil tank, oil pan and breather
Jazz 2 gallon fuel cell
ATI damper
Custom intake manifold with 8 injectors and fuel rails
All piping done
DSS hubs
Gauges
Simpson window net
B & M shifter
1 wire race alternator
MSD coil packs
Weldon fpr
Stroud parachute
OMP steering wheel
Jamar staging brake
Old Oct 11, 2016 | 06:18 PM
11SECEG's Avatar
Gforce dogbox
mfactory lsd
speedfactory scha
fully inspected by dp performance
replaced all worn parts with receipt
Zero miles after rebuilt
Im asking 5500 obo
call or text 510 415-0544
new modified / reinforced casing
Old Oct 19, 2016 | 11:44 AM
hondaracing84's Avatar
Starting a new project so I need to get rid of some parts I no longer need.
All parts are used but in good condition. Paypal required unless local pickup, buyer pays PayPal fees. And sorry, no international.
Serious inquires only. PM me or for quicker response text 580-382-1661.
I am willing to do trades if its a part that I need for my new project. So let me know.
Mfactory Pro Series 4.05 final drive for B series GSR. - $310 shipped
Supertech 100 series flat face performance valves. These are NOT the stock replacement, they are the performance valves and have the logo at the top of the stem. Half are brand new in package the other half are used. - $160 shipped
Eagle LS length rods. Used for 2 seasons in an all motor application. Rod bolts torqued a few times when checking bearing clearance and twice for final assembly each season. - $220
AEBS sleeved GSR block w/caps. All motor 86mm bore, needs hone. Pistons to match can be included for extra cost, listed below. Block once was turbo, so it had o-ring grooves. Copper rings were pressed in and smoothed out to fill grooves. - $600 + shipping. Local pickup preferred, will drive to surrounding areas or meet halfway to deliver.
86mm Supertech 13.5:1 compression pistons. One cylinder had some detonation and resulted in some marks on the piston. I will sell the pistons by themselves or with the block. Comes with wrist pins. - $175 or $150 w/block
Competition Clutch Twin Disc. Good condition, came off running car.
Missing one bolt, can be purchased at a hardware store. M8x1.25x45 Was going to sell my spec twin disc clutch, but it needed a new flywheel. I figure it would be easier to sell the CC twin and buy the flywheel and use the Spec. However, if you would rather have the spec clutch, Ill sell it for 500 + shipping. Otherwise the CC twin disc clutch - $750 + shipping
Old Oct 20, 2016 | 10:10 AM
sohc95vtec-t's Avatar
Parting out SFWD del Sol. If you don't see it listed, just ask as it's probably for sale (shell not FS)
Car is still in 1 piece. Parts will be removed as they are sold, and will try and update with more photos as parts are taken off. If more detailed individual pics are wanted, please message me. No expense was spared on this build, and everything is in great condition. If you see anything in the photos that isn't listed, please message as it is probably for sale.
Longblock - AEBS sleeved/o-ringed B18c1 block, Carrillo pro-H Rod's (upgraded CARR bolts), CP 9:1 pistons with upgraded wrist pins. Stock port GSR head, Supertech valvetrain and Ferrea 6000 series newer spring style LMA's, ARP intake & exhaust manifold studs. Will not include valve cover, water necks or any accessories. - $3500 (or $2300 for short block (no accessories) $1200 for assembled head, with valvetrain & ARP intake/exhaust studs (no cams/VC/etc)
T1 Spec Web Cams - $ 495
ATI race damper - $250
Hondata s300 v3 - $600
Hondata CPR kit - OEM distributor with Locash cap, RyWire COP plate, new coils, and CPR box with sub harness. - SOLD
Edelbrock Victor x intake manifold (GSR) - $250
Edelbrock 76mm Throttle body w/ adapter plate - $250
JDL designs top mount & 3.5" DP Borg Watner v-band. T4 divided, dual 38mm v band flanged (tial mvs). - $800
Tial MVS black - $200 (only one available)
T1 Race custom intercooler, with custom 3" piping. Includes all Wiggins clamp connections (4 total). Intercooler and piping are anodized black. - $1200
Golden Eagle fuel rail & gauge - $120
ID1000 injectors (x4) - $300
Weldon FPR - $150
Sheepy/HHfab catch can, valve cover with lines/fittings. Black anodized can with ARP hardware - $350
FCS 9 gal street fuel cell with sending unit - SOLD
Fuel system for above fuel cell. Dual Bosch 044 pumps, Weldon pre & post pump fuel filters, -8an feeds, with -6an return. All lines and fittings from fuel cell to rail and back. - $650
B series transmission with Quaife LSD (5th gear was used and out of another transmission so it wines). Gears are LS 1-2, B16 3rd and ITR 4, unknown 5th. Kind of a bastard set up, but it works lol. Gears are Racersteve treated and all have very low mileage/usage - $1100.
CNC worx 5th gear handcuff - $150
DSS 5.9's with GSR front spindles - $1350
Tilton twin disk - $1000
Progress drag coilovers, custom valves with 500lb springs front, 700lb rear. Some surface rust, but very low mileage - $750
Custom traction bar/weight ballast set up - SOLD
Kirkey seat - 16" width - $150 (1 available)
Avid Solid motor mounts - $250
Fluidyne radiator with -16an radiator lines. Includes engine side water necks for GSR - $300
Weld Magnum Wheels-
Fronts : 13x9, 5" Backspace, OMF Single beadlock fronts (screws on inner). All hardware replaced with ARP (~$170 upgrade). Anodized silver center, matching beadlock ring with polished lip. Wheels are in mint condition and will include a set of 24.5x9 Mickey Thompson slicks with ONE pass.
Rears : 15x3.5 1pc skinneys. Wheels are BRAND NEW, only one wheels was mounted for this photo. Polishing from weld wasn't to my standard, so I had these professionally mirror polished, and clear powder coated so that they will never have to be repolished again. Tires are M&H 24x3.6, with tons of life left. Wheels are brand new, and only a hand full of passes on the tires.
Wheels will include a set of lug nuts and spacers needed up front to clear GSR sized brakes
Front beadlocked Welds with MT slicks (1 pass) - $1550 plus shipping
Rear Weld 1pc skinnys with M&H tires - $1250 plus shipping
Package deal (fronts & rears with lugs) - $2600 plus shipping
Old Oct 20, 2016 | 09:46 PM
2point0VTEC's Avatar
2001 Honda Insight (old blueprint drag car)
Motor:
K24 block
99mm Blueprint crank
88mm Wiseco piston 14:1cr
Blueprint rods
K20 Type S head
Port and polished by Blueprint
Blueprint Ti retainers and valve springs
Blueprint stage 4 cams
Skunk2 ultra Race intake manifold
Ktuned 90mm Tb with Ktuned tps
04 type S 6spd
brand new Carbon synrcos gears
wavetrac LSD
Clutch master Twin disc
ASP header
Afco radiator
Meziere external water pump
The car was just recently tuned at Church Automotive. Made 360 hp, 240 tq.
Susepenion:
Front:
RSX 5 Lug with Custom Lower control arms
Rsx shocks, GC coil over sleeve, Eibach springs
Arp extended studs
Rear:
Carrera shocks
Eibach drag springs
NHRA cert. 6 point bolt in chromoly cage by Castle Fab.
(had to be bolt in because insight chassis is Alum.)
24.5x8.5x15 M&H slicks mounted on Bogart
15x3 M&H slicks mounted on bogarts
ALSO have the stock motor and battery Pack which will be included with the sale of the car.
Pretty much the run down on the car. I might be forgetting some stuff. Feel free to msg or email me if you have any questions.
Car is located in Long beach, Ca.
Email: Sam@importlife.com
ASKING $15,500 or $17,000 with Dogbox tranny
Old Oct 27, 2016 | 09:48 AM
Kash Racin's Avatar
81.5 mm je 10.1 Pistons great skirt and piston condition asking $250 willing to ship
Located in Brooklyn ny
email kashracin@gmail.com if u can't reach me here
Old Oct 30, 2016 | 03:57 PM
Bentley454's Avatar
AEM 30-6050 Series 2 EMS
Obd2B 00-01 Integra, 99-00 Civic or universal with custom harness.
Jumpers set for T1 Cam Trigger, I can change these back if needed.
Can get pictures for interested buyers.
850.00us buyer pays shipping.
Clayton
Oct 25, 2017 12:43 AM
crazes
Feb 1, 2017 11:37 AM
crazes
Nov 18, 2016 05:52 AM
crazes
Oct 3, 2016 01:58 PM
crazes
Sep 5, 2016 02:16 PM
