-March FS Thread-
Old Mar 12, 2012 | 10:13 PM
  #51
forty-five's Avatar
Default Re: -March FS Thread-
NOS 4 FOGGER NITROUS KIT FOR SALE ITS NEW BUT USED. IT WAS INSTALLED BUT NEVER USED
COMES WITH ALL LINES, SOLENOIDS, 8 JETS, BOTTLE, AND BRACKETS
ASKING $ 400
LOCATED IN JAMAICA NY 11434
631 492 0994
Old Mar 12, 2012 | 10:45 PM
  #52
forty-five's Avatar
RED JDM RECARO SEATS (PAIR)
AND RED ARM REST COVER
SEATS COME WITH EG RAILS
ASKING $ sold sold sold
631 492 0994
JDM ITR CLUSTER MINT CONDITION $ 125
86 MM DART SLEEVED BLOCK JUST NEEDS A CLEAN ALL MACHINE WORK ALREADY DONE $ 800
Old Mar 13, 2012 | 09:22 AM
  #53
c-techracing's Avatar
weldon 2025-A fuel pump. it has about 15 dyno passes and 4 runs down the strip. never used it after i had weldon checked to make sure seals and pump is running fine. have papers to prove it. sakata motorsport verified!!!! 951 233 1319
$450 obo
92-95 eg fal rearl hatch lexan. in very good condition.
$175 obo....
http://www.flickr.com/photos/41026446@N04/6833557476/
http://www.flickr.com/photos/41026446@N04/6833557364/
Old Mar 13, 2012 | 09:48 AM
  #54
ineedavtec's Avatar
SOLD
Old Mar 13, 2012 | 12:58 PM
  #55
poundedhatchcrap's Avatar
I have a front mount turbo manifold we made for an EF chassis. Its flanged for a T3 turbo and a tial 44mm wastegate flange as well. I made great power with it, 735 at 21 psi with a pte 67. Full stainless steel Inch and a half mandrel bends.
Looking for 700$
Old Mar 15, 2012 | 02:17 PM
  #56
BioXide02's Avatar
Looking to sell the following, both used and are in good shape. I am located in Eugene, Oregon and accept Paypal for payment.
1) Full Blown Dual Pump Hanger w/ 2 walboro pumps. No lines included, but I will throw in the top fittings as seen in the picture below. -10 feed -8 return. $375 Shipped.
2) AEM 3.5 Bar Map sensor, no pig tail included - $85 Shipped.
Pictures located here - http://hondamarketplace.com/showthread.php?t=3036912
Old Mar 15, 2012 | 03:10 PM
  #57
DxTrix's Avatar
h22 Hytech turbo manifold t4 divided with egt bungs bottom mount turbo placement $900
--h22 109 stroker setup never been used 109 welded crank, ross 90mm max dome pistons 16:1 compression and Cunningham rods $1000
--h22/h23 Arias 89mm bore with a 95mm crank 16.5:1 with a 90mm crank 15.5:1 pistons new with pins, locks and rings $550
--h22 arias 87.5 9:1 pistons new with pins, locks, and rings $400
--h22 cp 87mm 9:1 turbo pistons brand new $400
--h23 block no pistons no rods. Comes with crank girdle and main caps block was notched for h2b $300
-jdm h22 bare block only nothing besides the block itself $100
--jdm h22 block .25 over sized with aftermarket liners can be used with aftermarket pistons no pistons no rods. Comes with crank girdle and main caps. $500
Old Mar 15, 2012 | 03:20 PM
  #58
thegr8one013's Avatar
Obd1 h22 injectors w/ resistor box $80
H22 alternator relocater kit w/ alternator $100
(it moves the alternator 1/2 inch over so the pulley clears without having to hit the frame
H22 rmf replica headers $300
These r the ones that full throttle sells. They are already modified to fit on the h2b motor.
2.5 inch mandrel bent exhaust system $120
It comes with a magnaflow muffler. It came off a eg 4dr n I was told it will fit a coupe also.
Located in Inwood, NY 11096 (near green acres mall)
Call/text me at 516-330-6190
Email me at cargrul@gmail.com
Old Mar 18, 2012 | 09:42 AM
  #59
West Werks's Avatar
Default K20/24 Adapter Plate
K20/24 Adapter plate to to a SBC/BBC Bellhousing. Blank plate (besides dowel pin locaters) for unlimited options. 24"x24" .625" 6061-T6 CNC'd inner ring, starter provision and dowel pin holes.
Old Mar 18, 2012 | 12:48 PM
  #60
GodFather of Boost's Avatar
Aeromotive Proseries pump $400
06 and up Civic SI header $250
Thermal 3" exhaust for ek coupe $400
MSD digital 6+ and HVC 2 coil $350
Custom Hotrod turbokit $2500 complete
Will part out turbokit.
Old Mar 19, 2012 | 06:24 AM
  #61
JdM iGeN's Avatar
Custom NOS/ZEX Direct Port Kit - $600
*Currently jetted for 120shot. This is essentially two full nitrous kits in one! Comes with 4 Custom Pre-Bent SS Lines, 4 ZEX Single Fogger Nozzles, 4 ZEX 0.030 Jets, 1 Evenflow distribution block, 1 ZEX 3' Purple Steel braided Line, 2 10lb NOS bottles, two NOS Sniper Nitrous Solenoids, two NOS Sniper Fuel Solenoids, 2 sets of 15' -4 AN Steel braided line, 2 sets of bottle brackets, 1 Edelbrock 10-15lb Bottle Warmer, 2 NOS "Shark" Nozzles, 2 NOS Fuel Taps (for Wet setups), 1 NOS Bottle Pressure Gauge w/fitting, ZEX Blowdown tube w/internal threaded fitting.
Old Mar 19, 2012 | 04:01 PM
  #62
RedneckRicer's Avatar
This is a complete package. Motor, EMS, Gauge, Turbo. Quality parts used. All parts are Brand New Never Used
Serious Buyers only. Total spent on this build is $15,753.
Buyer pays actual shipping cost.
Cash, PP Gift or you Pay 3%
Long Block $7400 $9635 spent
Motor is a B18C Built by ERL Performance
-Manley H-beam Rods
-Wiesco Coated Skirt 8.5:1 Pistons
-ERL Superdeck Sleeves
-ARP Headstuds
-ARP mainstuds
-Moroso 5 qt pan with bungs for turbo drain and temp sensor
Oil Pump, Oil Pickup, Water Pump Timing belt. New Bolts used throughout whole engine. New water pipes, thermostat housing, all new gaskets seals All OEM Honda parts
Cylinder Head- Integra Type R head
-Integra Type R Camshafts
-M factory Camgears
-Supertech Valvesprings and Titanium retainers
-Supertech nitride coated valves
- New valve seals, Cam cap bolts, valve guides, cam seals all OEM Honda
Turbo setup- $2200..... retail $2650
-SLS Topmount manifold with 3" 5 bolt downpipe
-Precision SC61 6152SP Turbo
-Precision 46mm Wastegate with several springs
Edelbrock intake manifold with AEM Fuel Rail Injector Dynamics 1000cc Injectors. 70mm Throttle body new OEM TPS sensor, Hondata 4 bar map sensor
EMS- $790
-Hondata S300 with Electronic Boost Control
-AEM Wideband sensor
Block also has 2 10AN fittings on the back for a breather setup
Custom Backdoor Intercooler with PWR core 24x12x3.5 $650+shipping
Carbon Kevlar Roof Cap for those who dont want to do a sunroof plug. plus it looks badass. 1600+ shipping
Old Mar 20, 2012 | 06:06 AM
  #63
B100sst's Avatar
Dc2 or Eg Bseries innovative motor mounts 95a. Mint condition $230. 2032782806
Old Mar 20, 2012 | 08:38 AM
  #64
JTauto's Avatar
1 set ofFuel Injector Clinic 2200cc injectors low impendence for $250.00
1 set of Precision 1600cc injectors low impendence for $220.00
1 FJO injector drive box $150.00
Old Mar 20, 2012 | 09:00 AM
  #65
Mr.J37's Avatar
B Series Test Pipe $60 Shipped
Go Tech StandAlone $350 Shipped
DA Auto to 5 Speed Mount $80 Shipped
Nippon ZC Pistons $60 Shipped
OBD2-RDX Injector Clips $25 Shipped
Iridium #8 Plugs $30 Shipped
Comp Engineering 3/8npt bungs Fuel Sump $60 Shipped
Old Mar 20, 2012 | 01:41 PM
  #66
Themouse's Avatar
FS: RC1600cc Injectors Saturated-SOLD
FS: Brand New FCS Fab Gas tank with Dual walboro in tank option-$600obo
FS: Full Blown In Tank Dual Walboro kit with all lines fee and return, and Fuel filter, Custom tank cover( so that lines are covered), -10AN feed -8AN Return-BO
Old Mar 20, 2012 | 08:31 PM
  #67
Boostfed86's Avatar
Upgrading to a Full-Race Twin scroll so I need to part with my current manifold. It is a custom T4 single scroll topmount that I built last year. It is constructed of Schedule 10 stainless and has been painted black. Recently made 600 with this manifold on 18-19 Psi with my S368. I had some boost creep issues with this manifold, however, I would imagine it would be fine with a smaller turbo and or stock head/cam combo. I am including a TurboSmart Progate48(48mm) wastegate and Mild steel dumptube which has been used on a X275 Racecar for 6 track visits and about 4-5 hours dyno/street time on my car. It is currently on my car however I will be removing it within the next few days. This manifold will require minor clearancing for EG chassis with large frame turbo, however I would expect it to clear fine on EK/DC. $600 shipped for manifold with gate and dump tube.
Please call/text for more info, 919-697-5922, I rarely check PM's.
Old Mar 20, 2012 | 10:51 PM
  #68
SonicRacing1's Avatar
26X10 MH slicks with 15x10 Bogart Wheels $650 any questions PM plz
Old Mar 21, 2012 | 05:22 AM
  #69
Innes's Avatar
Email -- James@IPGParts.com
Phone -- 407-324-4684
We have an enormous amount of awesome used Drag Racing Parts available
way too much to post here
here is a Text Only List that we generated to start with -- http://www.ipgparts.net/blog/general...learing-house/
and here are some of the great highlight parts
-- Mark Williams Axle Kit for 92-00 Civic, 94-01 Integra (Spindle, Brakes, Axles, Intermediate Shaft) — $2800
-- MB Racing Fiberglass Doors for 92-95 Honda Civic (includes lexan, latches, etc) — $600/pair
-- Nuformz Rear Spindle Mount Suspension with Strange Coilovers for 92-00 Civic, 94-01 Integra — $1800
-- Bogart Wheel for Nuformz Rear Spindle Mount Suspension Setup — $750
-- Penske Front Coilover for 92-00 Civic, 94-01 Integra, Remote Reservoir, Drag Valved — $1375
-- GM 4T65 Auto Race Transmission with K Series Adapter Plate and 2nd Mockup Transmission Case — $2900
-- Precision 6265 Journal Bearing Turbo, T4, 0.81 A/R, S Cover — $775
-- Weldon 2015 Fuel Pump — $495
-- Bogart 15×10 Double Beadlock Drag Wheels with Dunlop 28x10x15 Tires — $1200
-- Z10 B Series Wet Sump Oil System -- $750
and the list goes on, and on, and on -- check it out here -- http://www.ipgparts.net/blog/general...learing-house/
Old Mar 21, 2012 | 08:46 AM
  #70
DXB16Coupe's Avatar
Contact Info:
Jordan holland
Whipple Ohio
740-629-4669
Item Description:
Up for sale is my turbo kit of my 99 si *it made 612 @ 24psi on my built sleeved gsr... It's a bolt on kit for b series heres a list of what it comes with as specs*
Also will be pickup only prolly not gonna ship these.... NOT SEPERATING THE KIT YET
Hondata s300 with jumper harness for OBD2B-OBD1*
Persicion sc6265*
Custom top mount Mani
Tial 44mm waste gate with dump tube*
3 inch down pipe*
Custom aluminum 2.5 in charge piping*
Turbonetics bov*
Intercooler*
Looking for 1700 or trades really looking for k20a2 stuff like motor trans dropouts ect.*
Also have the trans from the setup its a 4spd liberty faceplate cuffed trans with carbon 1-4 synchros has LSD I belive m factory it had a slight grind going in to 2nd an would go in fine if you shifted slow knowing it has that problem im asking 1300 pretty firm...
Will have more parts up after these sell
Old Mar 21, 2012 | 10:00 AM
  #71
2fast4u831's Avatar
I'm really 2slow
BNIB: Bullseye Power S372R Turbo. specs on turbo: 71.8mm inducer and 101.8mm exducer on the compressor side. 83.4mm inducer and 73.4mm exducer on the exhaust side. T4 divided, 1.10 A/R, 3" outlet discharge and 4" exhaust side. has a polished race cover and high temp. coated exhaust housing. Everything is brand new! $1,200obo. I will throw in a free downpipe clamp with the purchase. let me know,Surge 831 359 0477.
Old Mar 21, 2012 | 04:27 PM
  #72
STaNkFaNgaZ's Avatar
Icon3 Re: -March FS Thread-
Contact: PM's or AiM
Hey everyone I have some used Full Race charge pipes (K-series) 2.5inches with couplers an T-bolt clamps! These pipes are for the vertical intercooler set-up. Im looking to get 100.00! (FiRM) Need them gone asap. im willing to drive up too 30miles within area.
If you need more pics feel free to PM me!
Old Mar 21, 2012 | 06:34 PM
  #73
ImportSports's Avatar
We are selling our B Series All Motor car. It is a 1990 Civic Hatchback body with a LS Vtec engine. The car has been several 11.0’s at 123mph, but could go 10s with a few minor changes. It would also be a perfect candidate for an H2B setup. This car would be a great platform to get into the all motor class. Below is a list of most major parts, but feel free to email for more specifics. I would like to sell the car complete, however if there is enough interest I would consider parting it out. I am asking $10,000 turn-key. A full list of parts is attached. Please email me with any questions at importparts@verizon.net.
File Type: doc
Old Mar 22, 2012 | 04:02 PM
  #74
richiefromoxnar's Avatar
Paypal certified
For quick response reach me at 805-302-1307
Forged Eagle H beam rods
$300
Ls crank
.10 under
Recently polished
$100 obo
Old Mar 24, 2012 | 12:16 PM
  #75
Tteiv's Avatar
Precision 6265 billet wheel T4 96 A/R. 400 miles on it. - $725.00 shipped
FJO injector driver - $160.00 shipped
text me for more info and pictures 816 225 0335.
